Broadlink issue “runtimeError”
Hello everyone. I’am connecting broadlink ti HA by https://home-assistant.io/components/switch.broadlink/ and I’m now on “9. sudo python setup.py install” and getting this “RuntimeError: autoconf error” in the end. What am I doing wrong?
Wrong version of python?
Mine is fresh. Should I really use 2.7? Is it the reason?
Will try it tonight
You may want to read thru’ this thread …
I have changed “getBroadlinkSharedData.py” to fresh one with python 3, and did my way again, but the issue is with “setup.py” (its inside “python-broadlink” which i got on 7 step), so I get the same issue. Seems to me, “setup.py” should be changet for python3, but how did others do? Apparently, I’am doing smth wrong…
You only need to do upto step 5 anyway! You only need 6,7,8,9,10 to send a test code, but you can skip that and just put the codes into HA since Rene’s code provides the yaml for you with the correct base 64 codes.
