Hi, a year or so ago I managed to get HA and broadlink working on my synology ds214. I upgraded to ds218 and now having issues getting it to work.
I’m running HA 0.64.3 due to the python version restriction. In order to get HA running I also needed to change pip to 9.0.1.
Logs indicate that it tries to install broadlink==0.5.1 but then errors out.
2018-11-06 23:43:14 INFO (Thread-7) [homeassistant.util.package] Attempting install of https://github.com/balloob/python-broadlink/archive/3580ff2eaccd267846f14246d6ede6e30671f7c6.zip#broadlink==0.5.1
2018-11-06 23:45:34 ERROR (Thread-7) [homeassistant.util.package] Unable to install package https://github.com/balloob/python-broadlink/archive/3580ff2eaccd267846f14246d6ede6e30671f7c6.zip#broadlink==0.5.1: Command “/volume1/@appstore/py3k/usr/local/bin/python3 -u -c “import setuptools, tokenize;file=‘/tmp/pip-build-w4bm964n/pycryptodome/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(‘\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-emn4hj_5-record/install-record.txt --single-version-externally-managed --prefix --compile --user --prefix=” failed with error code 1 in /tmp/pip-build-w4bm964n/pycryptodome/
2018-11-06 23:45:34 INFO (MainThread) [homeassistant.core] Bus:Handling <Event system_log_event[L]: exception=, level=ERROR, timestamp=1541565934.5832355, source=util/package.py, message=Unable to install package https://github.com/balloob/python-broadlink/archive/3580ff2eaccd267846f14246d6ede6e30671f7c6.zip#broadlink==0.5.1: Command “/volume1/@appstore/py3k/usr/local/bin/python3 -u -c “import setuptools, tokenize;file=‘/tmp/pip-build-w4bm964n/pycryptodome/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(‘\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-emn4hj_5-record/install-record.txt --single-version-externally-managed --prefix --compile --user --prefix=” failed with error code 1 in /tmp/pip-build-w4bm964n/pycryptodome/>
2018-11-06 23:45:34 ERROR (MainThread) [homeassistant.requirements] Not initializing switch.broadlink because could not install requirement https://github.com/balloob/python-broadlink/archive/3580ff2eaccd267846f14246d6ede6e30671f7c6.zip#broadlink==0.5.1
I tried installing broadlink directly using pip but 0.5.1 isn’t available. So I tried every main version. The only version that installed successfully was 0.2. But even with that installed, when I run HA, it still tries to install 0.5.1 and fails.
The error I see when installing all the newer versions of broadlink:
/usr/local/arm-unknown-linux-gnueabi/bin/arm-unknown-linux-gnueabi-ccache-gcc -Wno-unused-result -Wsign-compare -Wunreachable-code -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -DSYNO_FIX_FLAG_BUG -DOPENSSL_NO_SSL3 -DOPENSSL_NO_SSL2 -mhard-float -mfpu=vfpv3 -march=armv7-a -mcpu=cortex-a9 -mtune=cortex-a9 -DSYNOPLAT_F_ARMV7 -O2 -fno-diagnostics-show-caret -Wno-unused-local-typedefs -include /usr/syno/include/platformconfig.h -DSYNO_ENVIRONMENT -DBUILD_ARCH=32 -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -g -DSDK_VER_MIN_REQUIRED=600 -pipe -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -D_FORTIFY_SOURCE=2 -O2 -Wno-unused-result -fPIC -DLTC_NO_ASM -Isrc/ -I/volume1/@appstore/py3k/usr/local/include/python3.5m -c src/MD2.c -o build/temp.linux-armv7l-3.5/src/MD2.o
unable to execute ‘/usr/local/arm-unknown-linux-gnueabi/bin/arm-unknown-linux-gnueabi-ccache-gcc’: No such file or directory
error: command ‘/usr/local/arm-unknown-linux-gnueabi/bin/arm-unknown-linux-gnueabi-ccache-gcc’ failed with exit status 1----------------------------------------
Command “/usr/local/bin/python3 -u -c “import setuptools, tokenize;file=‘/tmp/pip-build-onf7rhfo/pycryptodome/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(‘\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-p42m8zqk-record/install-record.txt --single-version-externally-managed --compile” failed with error code 1 in /tmp/pip-build-onf7rhfo/pycryptodome/
Any suggestions?
