i have broad link light switchs all over my house on the broadlink app it tells me witch lights are on and off can i show in hass.io what lights are on and off next to a switch ?
thanks
thanks
Is it a 433MHz light switch that you have?
it links to the app on broadlink controller via BroadLink RM PRO+ > wifi
yes i read up on http://www.ibroadlink.com/tc2/ and says 433mhz
Ok so you can’t have the actual state of the switch as it only can receive datas. If you push the switch OFF physicaly the state in the app will still be ON
its seems to transmit state what it is doing so i can see what lights are on and off i duno if app checks or if when it changes it tells rm pro i belive , ill double check later tho
you are right only tells me when i use app to switch it , makes things easier i guess
