MP2 run perfectly. you can force sp2 instead of mp2 in your configuration.yaml
Hello garvarma does this work synonymous for broadlink SC1? Thank you in advance
Sorry but i dunno, because i donāt have SC1 broadlink. But i can read some post before, https://community.home-assistant.io/t/broadlink-mp1-mp2-controlled-switches-support/7790/74?u=garvarma
if you complete all these data
platform: broadlink
host: IP_adress
mac: AA:BB:CC:DD:EE:FF
friendly_name: "VMC"
type: sp2
It will work.
Yes, it does. I have several SC1 devices set as a SP2, an MP1 natively integrated and a RM-Pro.
SC1 are connected to two extractors, one small heating, and some lights replacing the switch.
Looks like the basic functions are identical to the SP2 so it works for SC1, MP2 too.
Knowing that, I think the SC1 is even better than the SonOff switches : itās almost the same price (inexpensiveā¦), it has a casing (nothing fancy but itās there) and itās native in HA.
After update HA from 0.56.2 to 0.65.5, now my broadlink mp1, is not recognized by HA in custom_components. I have this error:
Mi configuration file have this:
- platform: broadlink
view: yes
host: 192.168.1.142
mac: 34:EA:34:XX:XX:XX
type: mp1-1
friendly_name: GW_Xiaomi
view: yes
host: 192.168.1.142
type: mp1-2
friendly_name: TV_Play
view: yes
host: 192.168.1.142
type: mp1-3
friendly_name: EzCast
view: yes
host: 192.168.1.142
type: mp1-4
friendly_name: Decoder_RU
host: 192.168.1.141
mac: '34:EA:34:XX:XX:XX'
timeout: 15
switches:
tv:
friendly_name: "TV"
command_on: 'JgCEAxIADFQAASVJEg..'
command_off: 'JgCEAxMADFIAASZJEw..'
decoder:
friendly_name: "DecoderTV"
command_on: 'JgDIAAABJ5MTExITE...'
command_off: 'JgDAAAABJpQRFBEUER...'
airea:
friendly_name: "AireA"
command_on: ''
command_off: ''
# command_on: 'JgC+AF+AQCEeQSAeIx0/Ii...'
# command_off: 'JgC+ACUnE4AZSB5...'
aspirador:
friendly_name: "Aspirador"
command_on: 'JgBIAAABIpMSExIRERQRE...'
command_off: 'JgBIAAABIpMRExISEh....'
Someones knows why this? any solution?
thanks
I solved. the problem was, that in newest version of HA, was updates to define broadlink devices.
Someone make something, about reading the electricity consumption of each broadlink mp1 socket?
thanks
Does mp1 measure wattage?
I donāt think so.
the mp1 doesnt measure wattage
Hey
I went ahead and got a Broadlink MP1.
I can control the individual switches, however if i switch multiple switches on and off fairly quickly the on/off state in home assistant and the actual powerboard loose sync and the GUI is wrong and it takes about 15 seconds to update.
Does anyone else have this issue?
Dear Paxy;
thank you for the amazing work, but Iām new to the system, any canāt figure out where to start and how to get this code work for me.
Any guidelines for beginners to follow?
thank you
Hi, can the socket be controlled individually?
I donāt believe, I havenāt found configurations that allow this.
