have no idea since I was not able to open it. I may just do that (destroying it) and see if it fits
I saw a picture of the inside online, but now I do not find anymore
Hi giangvo,
I installed your PR as a custom component.
It works very well and looks great!
Thank you so much~~
Itās a typical shitty engineered Chinese product: not good for inside (too big and need to reset pushing a button) not good for the outside (ugly)
Hows the commit going for this change? Just wondering as Iām using hass.io and cannot update the scrip manually.
Itās still under review. It takes quite a lot of time to review back and forth. Will try to push it out soon
Thanks. On a another note, has anyone pulled the mp1 apart and removed the covers that stop 2 pin AU plugs from being plugged in.
I merged the PR so it should be released in new version soon :). Cheers!
This product is compatible wiyh HA:
MP1 support has been released in 0.54: https://home-assistant.io/blog/2017/09/23/release-54/ . Yay!
hey guys, is it possible to integrate mp2 at the moment?
Hi guys,
Iām just wondering if the Broadlink SC1 Wi-Fi switch ever got integrated? Thought Iād ask before I order some
Thanks,
Lint
Should work as an SP2 (no consumption tracking), see this shared configuration : Thanks to TomerFi
I have 2 arriving by the end of the week, Iāll be sureā¦
Lol, was going to go for these once they worked with HA but have now gone Sonoff instead as you can do more with them. My ātestā SC1 is still unopened and unloved but now we know they work Iām sure I can find a usp for them.
Received 2 SC1 and a RM3 pro.
SC1 work as expected, forced the SP2 type in the switch configuration and I get status/on/off from HA.
platform: broadlink host: !secret sc1_host mac: !secret sc1_mac friendly_name: "VMC" type: sp2
Got them for 5ā¬ each delivered, very nice device for the price. Way too big to integrate in a wall box but I plan to use them also for manual activation too (bathroom heater, multi-plugā¦)
You can configure them with the Android application, works even if the SSID is different from the phoneās (but the phone has to be connected to a wifi network though) and doesnāt need to āphone homeā at all.
RM3 is another story, but it belongs elsewhereā¦
Next Iāll be trying an MP1 device.
Hello Mister_Slowhand
I have a SC1 Boradlink device and I would like to add it in my HA.
I have seen your description but I have a doubt about how I turn on and off using HA.
Could you share this code part?
thanks
Oescafandrista
Sure, here is what I have.
First, you have to declare the switch, as posted above. Letās call it āsc1ā to be originalā¦ Depending on your configuration it may be slightly different (I use a split configuration with an include in main configuration.yaml) :
- platform: broadlink host: !secret sc1_host mac: !secret sc1_mac friendly_name: "sc1" type: sp2
Then you can refer to it, for instance in a group display :
Group1: view: yes name: broadlink control: hidden entities: - switch.sc1
For automation, Iāll show you 2 examples that work together.
First one turns the sc1 on when someone arrives (itās a bayesian sensor āsomebody homeā that triggers it) and itās dark outside (welcome light) :
- alias: 'Welcome Home' trigger: - platform: state entity_id: binary_sensor.somebody_home to: 'on' condition: condition: numeric_state entity_id: sun.sun value_template: "{{ float(states.sun.sun.attributes.elevation) }}" below: 2 action: - service: switch.turn_on entity_id: switch.sc1
Second one turn this light off after 10minutes whatever triggered the turning on. So with this automation, even if you press the sc1 button, it will be turned off after 10minutes :
- alias: 'End welcome light' trigger: - platform: state entity_id: switch.sc1 to: 'on' for: minutes: 10 action: - service: switch.turn_off entity_id: switch.sc1
Iām using several Broadlink products (MP1, SC1, RM-Pro) as they integrate very well with HA, they donāt need to āphone homeā some chinese server, theyāre inexpensive (I buy from any aliexpress store, wait 2 weeks for delivery, and get a SC1 for ā¬5, MP1 for less than ā¬20ā¦).
The main default of this solution is the lack of some functionalities : contrary to SonOff, they only have a 220V switch, no dry relay and sensors are expensive (itās a ādesignā device that goes for over ā¬30, itās really too much if you just want temperature in 3 rooms !)
I just bought a Broadlink MP2 but it doesnāt work as the default Broadlink switch RM component (https://home-assistant.io/components/switch.broadlink/).
It seems MP2 was not supported any more? Please give me any suggestions to make MP2 work under Home Assistant.
Thank you.
I donāt think MP2 was ever listed supported ? I saw MP1 (and I use one), but no MP2.
Have you tried to force the device type to MP1 and see if it handles the 3 plugs ?
Iāve tried to define MP2 as MP1 config but it doesnāt work.
Look in the python component, looks like the MP2 isnāt supported as is.
But I found a report saying that MP2 was used as a SP2 : https://github.com/mjg59/python-broadlink/issues/51
I have some SC1 devices, theyāre working when forced as SP2 too.
I donāt know how MP2 works, can you control each plug individually ? Or is it an on/off for the 3 of them ? Does it report power usage ?
MP1 has individual control of the plugs and no power usage report.
