Broadlink not working since 0.64
Since I upgraded to 0.64, I have my broadlink switches aren’t displayed anymore and I have 3 error messages :
Timer got out of sync. Resetting
21:48 core.py (ERROR)
Error while setting up platform broadlink
21:46 components/switch/broadlink.py (ERROR)
Module name: "<function string at 0x758c5738>" not found
21:46 components/sensor/netatmo.py (ERROR)
What can I do to troubleshoot ?
Thank-you
Its a known error, apparently fixed in 0.64.1, though ive not tested it yet. Holding off for now :slight_smile:
Try 0.64.1, or rollback to 0.63.3
I rolled back to 0.63.3 :wink:
Does anyone know what is the ETA for 0.64.1?
It’s been released just takes a few hours for Hass.io users to get the update… Can be up to 48hours but normally within 24
Not working for me too. Will wait for 0.64.1
I’ve just tried 0.64.1 and still getting issues:
6:41 pm core.py (ERROR)
Unable to prepare setup for platform media_player.broadlink: Could not install all requirements.
6:41 pm setup.py (ERROR)
Not initializing media_player.broadlink because could not install requirement broadlink==0.5
6:41 pm requirements.py (ERROR)
Unable to install package broadlink==0.5: Could not find a version that satisfies the requirement pycrypto==1000000000.0.0 (from -c /usr/lib/python3.6/site-packages/homeassistant/package_constraints.txt (line 20)) (from versions: 2.0.1, 2.1.0, 2.2, 2.3, 2.4, 2.4.1, 2.5, 2.6, 2.6.1) No matching distribution found for pycrypto==1000000000.0.0 (from -c /usr/lib/python3.6/site-packages/homeassistant/package_constraints.txt (line 20))
6:41 pm util/package.py (ERROR)
Unable to prepare setup for platform climate.broadlink: Could not install all requirements.
6:40 pm setup.py (ERROR)
Not initializing climate.broadlink because could not install requirement broadlink==0.5
6:40 pm requirements.py (ERROR)
6:40 pm util/package.py (ERROR)```
Got it working here…
keep in mind I am on Docker :
docker exec -i -t home-assistant /bin/bash
and then:
pip3 uninstall pycrypto
pip3 uninstall pycryptodome
pip3 install pycryptodome
then I had to edit the MAC adres in the switch.yaml ( here its in secrets.yaml) There I had to remove the ‘:’ in teh macaddress so now the mac address reads : xxxxxxxx instead of xx:xx:xx:xx
Actually, I managed to get it working with the components I’m using by altering the broadlink==0.5 to become broadlink==0.5.1 as per the component in 0.64.1. :slight_smile:
I am using hassio. How do i upgrade to 0.64.1 or downgrade to 0.63?
Don’t see anything in the release notes regarding Broadlink?
Not ovbious, but its in this pull request, a few layers deep.
Don’t allow to use a old unsecure library (@pvizeli - #12715)
Thanks, updated and all good.
So, did this fix make it into .64.1?
Yes, if u have broadlink switches the dependancy has been resolved. Some users are still reporting climate broadlink issues but they need to create an issue on github.
My Broadlink Mini 3 is working fine in 64.1
Yep, mine all good.
Thanks guys! Upgraded to .64.1 and it is still working. I don’t know what I would have done if I had to press a button to turn on and off the tv now. THE HORROR!!!
Ha ha ha… That would have been a blast from past!!!
How do I do this? How can I alter the broadlink 0.5 to 0.5.1? I am running Hass as a Docker in QNAP Container Station.
