@Danielhiversen perhaps you can explain,
I have an OEM device with Broadlink tech in it and it’s Identified on my home network as spmini so that’s how I originally set it up in HA (the type)
It’s not working very well so I did some digging and found that the code it’s identified as is “0x7539” which falls under the category of the following line in the code I believe
took a while to remember code has changed much since…
try looking at
I believe I played around with “python-broadlink/broadlink/init.py” and printed the devtype from that code right after line 15 or something like that, then it was a matter of finding the specific code and which device it was associated with further below.
