explanation
I have multiple broadlink
remotes (docs).
When I use remote.learn_command
to learn an ir
code, it will save it to a database related to the remote device, for example, it will save codes learned on remote A
in /config/.storage/broadlink_remote_23dde4f45b9a_codes
and those for remote B
in /config/.storage/broadlink_remote_15dee4f48b2b_codes
This is fine in theory, but now when I try to run a code learned on remote A
via remote B
, I will get Fehler beim Aufrufen des Diensts remote.send_command. Unknown error
. When I run this command via remote A
, it works fine.
These files are in .json
format, so I can try manually copying the learned codes from remote B’s file to remote A’s file. However, I run Home Assistant on a local server via docker; the dockerfile seems to have been created in a way that it writes all (or most) data in /config/.storage
as root
within docker. So even though I have mounted the remote docker path on my local computer, I cannot edit these files (instead, I have to ssh to the local server, then edit them there) due to insufficient rights (mounted via sshfs
feature request
Allow learned codes to be collected in a central database, so that multiple remotes can access the codes - instead of having to learn codes per remote or having to manually edit files.
why
Other than the reason mentioned above (which is rather special / individual), I could imagine one that could benefit everybody:
if people used multiple broadlink
remotes, perhaps they’d place them all around their house (or even set them up for other people, such as parents, via homeassistant.remote
); in this case, it’d be so much more convenient to have one dedicated broadlink on ones desk to learn all codes, then replay those codes on other devices (basement, attic) without having to learn those codes directly on those remote devices.
