I updated my HomeAssistant to supervisor-2021.02.11 and after that Broadlink has stopped working. I looked at the revised documentation on https://www.home-assistant.io/integrations/broadlink and based on the instructions came up with the following:
switch:
- platform: broadlink
mac: 'mac:Address:here'
switches:
- name: "Upper Lounge AC"
command_on: "JgDmAG86DSwNKw0QDQ8NEA0sDBANEA0rDSwNDw0sDRAMEA0sDCwNEA0rDisNEAwQDSwMEA0PDSwNEA0PDRAMEA0QDQ8NEAwQDRANDw0PDRANDw4PDQ8NEA0PDSwNDw0QDSwMEA0sDCwNLA0PDRANDw0QDBANEAwQDSwMEA0sDBANEAwQDRAMLA0QDCwNLA0sDCwNEA0PDRANEAwQDQ8NEA0PDRANDw4PDBANEA0PDg8MEA0QDBANDw0QDQ8NEA0PDRAMEA0QDBANEAwQDRAMEA0sDQ8NEAwsDSwNDw0QDQ8NLA0PDRAMAA0FAAA="
command_off: "JgDmAHE4DyoPKg8NDg8PDQ8qDw4ODg8pDyoPDg0rDw4PDQ8qDyoODg8qDykPDg8NDyoODg8ODioPDg8ODg4ODw4ODw0PDg4ODw4PDQ8ODg4PDg4ODw4ODg8ODg4PDQ8ODyoODg8pDyoPKg8NDw4PDQ8ODg4ODw4ODyoPDQ8qDw0QDQ8NDw4OKg8ODioPKg8qDyoODg8NDw4PDQ8ODw0PDg8NDg8ODg8ODg4PDQ8ODw0PDg8NDw4PDQ8ODg4PDg8NDw4ODg8ODg4PDg4ODw4PDQ8qDw0QDQ8qDykPKg8pDyoTCRANDw4PAA0FAAA"
Prior to this I had following syntax
switch:
host: 192.168.1.26
mac: 'mac:address:here'
timeout: 15
switches:
dshutter:
friendly_name: "Shutter"
command_on: "sgD8AJYyFwwLGAwYCxgXDAsYFwwMGAsYCxgMGAsYCxgLGAsYGAsMGAsYCxgMGBcLDBgXDBgLGAsYDBcMCxgMFwwYCxgXDAwXDBkKGBcMCxgLGQsYFwABn50zFwsMGAsYCxgXDAwXGAsMGAsYCxgMFwwYCxgMFwwYFwwLGAsYDBcMGBcMCxgXDBcMGAsYDBcMCxgMFwwYCxgXDAsZCxgLGBcMCxgLGAwYFwABn50zFwsMGAsYCxgXDAsZFwsMGAsYDBcMGAsYCxgLGAsYGAwLGAsYCxgLGBgLDBgXDBcMFwwYDBcMCxgLGAsYDBgXDAwXDBcMGBcLDBgLGAsYFwAF3AAAAAAAAAAAAAAAAA=="
command_off: "sgD8AJgzFwwLGAsYCxgYCwwYFwwLGAwXDBgLGAwXDBgLGAsYFwwMGAsYCxgMFxgLDBgXDBcMGAwXDBcMDBcMGAsYCxgXDAwYCxgXDBcMDBgLGBcMFwABoJ0yGAsMGAsYCxgXDAsYGAsMGAsYDBgLGAsYCxgMGAsYFwwMFwwYCxgLGBgLDBgXDBcMFwwXDBgLDBgLGAwYCxgXDAsYCxgYCxgMCxgMFxgLGAABn50zFwwLGAwXDBgXDAsYFwwLGQsYCxgLGAsZCxgLGAsYGAsMGAsYCxkLGBcMCxgXDBcMGAsYDBcMCxgMGAsYCxgXDAwYCxgXDBgLDBgLGBcMGAAF3AAAAAAAAAAAAAAAAA=="
curtain_top:
friendly_name: "Curtain Upper Stairs"
command_on: "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"
command_off: "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"
uac_lounge:
friendly_name: "Upper Lounge AC"
After adding the new code in configuration.yaml I went to Developer Tools and set State = On for switch.upper_lounge_ac. Even though it set the state = On but Broadlink didn’t do anything. There was no light beep on the device or anything nor the the appliance turn on. I would be grateful if someone could guide a fix for this issue. Thank you
