gutopa
(Augusto Sala)
1
Hi All…
I’ve had a broadlink device working with IR and RF for a while.
The RF codes were discovered using this tutorial:
Everything was working fine until a couple of versions ago, but now I’ve got only the IR codes working… RF simply doesn’t do anything from HA.
Has anyone seen the same problem recently? I’m wondering if it’s a version change or if something else.
Thank you
Harry13
(George Georgas)
2
the only advise i can give you is to use the node red broadlink palette
node-red-contrib-broadlink-control
in HA it worked and then just stopped working
switch to node red and its never lost a beat since then
