Hi all!
We encountered a problem with Broablink. There are curtains in the house that work via an RF signal. The problem is that it works extremely unstable. Sometimes it works, sometimes it doesn’t, I can’t achieve 100% success.
Or I configure everything to work, but after a while I have to change the service:remote.send_command parameters in order to get all devices to respond, but again, this is temporary.
Sometimes turning off the on/off switch in the Broadlink integration helps. Sometimes not. it feels like the signals are somehow superimposed on each other and the end device does not receive the correct code.
I thought about it. Maybe it’s a matter of a coordinated setup approach when working with multiple devices?
*- service: remote.send_command*
* data:*
* num_repeats: 1*
* device: curtain_1*
* command: open*
* target:*
* entity_id: remote.main*
* - delay:*
* hours: 0*
* minutes: 0*
* seconds: 2*
* milliseconds: 0*
Friends! Share your experience if you have encountered such a problem!))
