Hi, I got recently a broadlink mini 3, connected it to my Wi-Fi and setup some remotes. Working fine, so next step is to bring it to home assistant. But I got problems with configuration. I tried different things from other posts in forum. Tried with timeout, with type but never could see my rm mini in hass. I tried to find it over dev tools with switch.broadlink, nothing, and no other tool with broad link in name. After adding a sample switch item from config page i could find the added switch. But because of dummy data it is not working.
Is there a way to configure a static ip for the device? Or only with mac address over router? That is a problem because my router (telekom speedport) can not do that.
Here my last config
- platform: broadlink
host: 192.168.1.110
mac: ‘34:EA:34:12:BA:AE’
friendly_name: ‘living’
type: rm_mini
timeout: 30
switches:
btv:
friendly_name: “Broadlink_Samsung TV Power”
command_on: ‘’
command_off: ‘’
How can i get the command codes when i do not see the switch.broadlink_learn_command. When i do not see that command does that mean then config is not working?
