INFO:homeassistant.loader:Loaded switch.broadlink from homeassistant.components.switch.broadlink
ERROR:homeassistant.bootstrap:Invalid config for [switch.broadlink]: [TV] is an invalid option for [switch.broadlink]. Check: switch.broadlink->switches->TV. (See ?, line ?). Please check the docs at https://home-assistant.io/components/switch.broadlink/
INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=persistent_notification, service_call_id=1978016304-1, service=create, service_data=notification_id=invalid_config, title=Invalid config, message=The following components and platforms could not be set up:
switch.broadlink
Please check your config>
INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=persistent_notification.invalid_config, new_state=<state persistent_notification.invalid_config=The following components and platforms could not be set up:
switch.broadlink
Please check your config; title=Invalid config @ 2017-01-17T14:17:12.492806-04:00>, old_state=None>
Can you post your config and maintain the formatting? This is likely a spacing issue in your config file. See below for how to post it with the formatting retained:
Thanks Daniel! Have you tried other commands that don’t don’t turn on and off? I am at work now and can’t post my config but I used e-control app to set up a set of codes ie. watch_espn 8 wait, .05 4 wait .05, 6 wait .05, enter. I have converted the hex codes to 64 but can’t seen to get it to work right.
