Broadlink RM Mini 3 does not work
I bought from
The firmware on this is 44057
Model: RM mini 3
FCC ID: 2ACDZ-RMMINI3-RM
On intelligent home center app from broadlink, the devices work as intended.It has no firmware upgrades available for it.On e-control app, it shows as unrecognized device, but shows.
On HA:
remote:
  - platform: broadlink
    host: 192.168.2.122
    mac: "xx::xx:xx:xx:xx"
and script:
script:
  learn_mute_tv:
    sequence:
      - service: remote.learn_command
          entity_id: remote.broadlink
          device: tv
          command: mute
When I called this service
device: television
command: Turn on
alternative: true
timeout: 30
I got that error message:
Logger: homeassistant.components.remote
Source: helpers/entity_platform.py:202
Integration: remote documentation, issues)
First occurred: 11:27:57 (4 occurrences)
Last logged: 11:32:30
Logger: homeassistant.helpers.service
Source: helpers/service.py:382
First occurred: 11:29:14 (31 occurrences)
Last logged: 11:32:49
  • Unable to find referenced entities remote.broadlink
Using broadlink manager gives the following:
Then I tried python-broadlink and BlackBeanControl
I changed the line 167, I wrote RealTimeout.
Then I got that:
What is the problem? Someone can help me?
Thank you in advance
From Banggood LINK
Then I got that:
BlackBeanControl
I tried as switch. I call a service (host: 192.168.2.122).
I got this:
Logger: homeassistant.components.broadlink
Source: components/broadlink/init.py:106
Integration: broadlink (documentation, issues)
First occurred: 19:19:28 (1 occurrences)
Last logged: 19:19:28
No signal was received
I too am struggling with my RM Mini3. I set it up perfectly about a year ago and it’s been working without issue. In the past few weeks the commands haven’t been going through on it, so I just checked and found this: https://github.com/mlfunston/node-red-contrib-broadlink-control/issues
I am checking my node-red logs, and am receiving the following error:
“Broadlink Timeout Received - Closing Device Connection”
I believe this is all part of the same issue.
Just found this post, Brodlink updated his firmware and broked the HA compatibility
Thanks, I checked.
I tried this method (with node-red), but during learning proccessing I get ““Broadlink Timeout Received - Closing Device Connection””.
I was dealing with the same issue. I’ve one older broadlink rm mini3 and one added 2 weeks ago. The newer one wouldn’t work.
Since Home Assistant 0.110.2 the broadlink library and integration got updated! When you have a newer broadlink rm mini3 use type: rm_mini3_redbean in your config.
If you’re still having issues, check: https://www.home-assistant.io/integrations/broadlink/#troubleshooting.
My Broadlink Minis have stopped being able to learn commands. It always used to work, but not any more.
