Hi Experts,
Im new to this Home assistant. I im configuring hassio 0.100.2 with my Broadlink RM mini 3. When i add the below command i get error please help what i did wrong.
*switch:*
* - platform: broadlink*
* host: 192.168.3.23*
* mac: 'C8:F7:42:83:12:36'*
* type: rm2*
* timeout: 15*
* retry: 5*
* switches:*
* # Will work on most Phillips TVs:*
* tv_phillips:*
* friendly_name: "Phillips Tv Power"*
* command_on: '260058000001209412371139123711131138121410131113113811141212113811381213111311381138123811381113141110391114103811141113121212371138111411381114100005300001244811000C4E0001254A11000D05'*
* command_off: 'JgAaABweOR4bHhwdHB4dHRw6HhsdHR0dOTocAA0FAAAAAAAAAAAAAAAAAAA='*
the thing that looks like its causing the errors is the * at the start and end of each line, that and your type is set to the wrong model.
once you get it working, forget the tv, look to the mini, there should be an led indicator light to show it is sending a signal, if that comes on then its working you just need to get the right code to send
I added a switch with a bogus command_on and command_off base64 string which caused the LED to flash on the Broadlink when toggled. This suggested to me that there was communication between the Broadlink and homeassistant.
this tells me ( and I am in no way an expert here iām still a noob myself ) that your switch works, now wee need to program the correct code and find thatā¦ give me a min or two and Iāll re-learn how I done mine.
but first do you have the broadlink apps installed on your phone/tablet ?
There is a opensource software called broadlink manager on windows platform, last time i used it worked like a charm. Just copy the code learned from the broadlink manager to HA configuration should work right away.
You have to have a windows machine,though.
the code captured would look like this : JgDKAI2QFDQTERI2EzQTERMREjYSEhIREzUTERISEjYSNRMREzUSEhISEhETNRM1EjYSNRM1EjYSNRM1ExETERISEhISERMRExETERISEjYSERMRExETNRI1EzUTNRISEjUUNBM1Eq2UkBM1ExESNRM1ExESEhI1ExETERM1ExESEhM0EzUTERI2EhISERQQEzUSNhM0EzUTNRI2EjUTNRMREhISEhIRExETERMREhISEhM0ExEUEBMREjYSNRM1EzUSEhI1EzUTNRIADQUAAAAAAAAAAAAAAAAAAA==
I had the broadlink apps installed on my phone. In home assistant
When I use services ābroadlink.learnā to learn commands, the error message above.
I used the software āBroadlink Managerā to learn commands. and
I have linked them
