I have added the switch for my Broadlink RM Mini to use with my LG tv. The switch is successfully added and the “on” command works but the “off” does not.
I used the codes as follows:
Maybe the code is not correct. Have you tried to send out the code with the dev-tools call service function? Just to see what happens. If the TV doesn’t react then the code is incorrect. Try to record it again.
So I tried using the same code for the command_on and command_off lines because the remote has a single button to toggle the power on & off.
No luck though.
Hello GAS, I think your formatting is not correct. “command_on” and “command_off” must have the same line indent from the left. Have you already tried this formatting?
Oh man! Tried all the suggestions but still not working!
Thanks to you all.
If ANYTHING comes to mind please let me know. For now I’m going to take it off my panel and see if anything better comes up to be able to switch this tv on & off.
