@Danielhiversen. yes - the switch does not show in the UI, the log doesn’t show any messages either.
I created a switch with my A/C remote code for COLD 23 degrees and another for HEAT 26 degrees, and it is working fine.
Both switches turn the A/C on and off, each with its own mode and temperature.
Does anyone know if is there a Discrete Code for A/C ?
Tried and got this error on log:
Testing configuration at /home/hass/.homeassistant
16-12-22 00:37:19 ERROR (MainThread) [homeassistant.bootstrap] Invalid config for [switch.broadlink]: expected a dictionary for dictionary value @ data[‘switches’][‘name’]. Got None. (See ?:?). Please check the docs at Broadlink - Home Assistant
Got it working without any error with this:
switch:
platform: broadlink
host: IP_ADDRESS
mac: 'MAC_ADDRESS'
type: sp2
switches:
name:
friendly_name: 'Humidifier'
I got the switch working on the web interface as well !!!
Another step forward !!!
Does the sp2 read energy consumption?
it work for my on sp3 .
thanks
you use only on /off switch?
work thanks
No power consumption here. I don’t think so.
I have a SPMini, two RM-Pro, and a A1, all working now, including the status info from SPMini when turned manually or from another app.
Hi rf code working fine.
Ir code of TV not working. The code is very long. Maybe I need to break it in 2 lines?
No errors in log
Usually very long codes are not working, and I think they are error results…
Try learning again and again and see if sometime you get a shorter one…
And I think that is not possible breaking the code into 2 lines…
ahh I understand, ok will try again
is the pycrypto error resolved?
Now I can’t get rid of it even doing sudo reboot (before with sudo reboot it would start well)
I just replaced my original in the components folder.
Rename the original to broadlink_old.pyold and copy the last one.
Erase all broadlink files from custom_components
That is the way I did.
Hi, I got it to work, it seems the friendly_name: ‘XYZ’ is mandatory?
(docs are a bit confusing at this stage - i took oliverdog’s as a reference)
the ‘status light’ which can be switched independently of the switch proper is not supported.
and the (initial) status is incorrect - assumes ‘off’
otherwise it seems stable, i’ll report back if/when i see some anomaly.
thanks for the good work and merry xmas y’all!
done but it still has problems
Hello @oliverdog. What is code length? Typically it should be 24bit. The first 16 bits are control id and rest are button id.
that’s one of my code
JgCEAw4ODg4ODg4ODQ4OKw4ODg4ODg4ODg4ODg4NDw0ODg4rDg4ODg4ODg4ODg4ODg0PDQ4ODisOKw4qDyoOKw4ODg4ODg4qDyoOKw4rDioODg4rDgAJlHM4Dg4OKw4NDw0ODg4ODg4ODg4ODg4ODg4ODg4OKg4ODg4ODg4ODg4ODg4ODg4ODg4qDg4ODg4ODg4ODg4ODg4ODg4ODioOKw4rDisOKg4ODg4ODg4rDisOKg4rDisODg4qDgAJlHM4Dg4OKw4ODg4ODg4ODg4ODQ4ODg4ODg4ODg4OKw4ODg4ODQ8NDg4ODg4ODg4ODg4rDg4ODg4NDw4NDg4ODg4ODg4ODisOKg8qDisOKw4ODg0PDQ4rDisOKw4qDisODg4rDgAJk3M5Dg4OKg4ODg4ODg4ODg4ODg4ODg4ODg4NDg4OKw4ODg4ODg4ODg4ODg4ODg0ODg4rDg4ODg4ODg4ODg4ODg4ODQ4ODisOKw4rDioOKw4ODg4ODg4qDyoOKw4rDioODg4rDgAJlHM4Dg4OKw4ODg0ODg4ODg4ODg4ODg4ODg4ODg4OKg4ODg4ODg4PDQ4ODg4ODg4ODg4qDg4ODg4ODg4ODg4ODg4ODg4ODioOKw4rDisOKg4ODg4ODg4rDisOKg4rDisODg4qDgAJlHQ3Dg4OKw4ODg4ODg4ODg4ODQ4ODg4ODg4ODg4OKw4ODg4ODg4NDg4ODg4ODg4ODg4rDg4ODg4ODg0ODg4ODg8NDg4ODisOKg8qDisOKw4ODg4ODQ4rDisOKw4qDisODg4rDgAJk3M5Dg4OKg4ODg4ODg4ODg4ODg4ODg4ODg4NDg4OKw4PDQ4ODg4ODg4ODg4ODg0ODg4rDg4ODg4ODg4ODg4ODg0PDQ4ODisOKw4rDioOKw4ODg4ODg4rDioOKw4rDioPDQ4rDgAJlHM4Dg4OKw4ODg0PDQ4ODg4ODg4ODg4ODg4ODg4OKg4ODg4ODg4ODg4ODg4ODg4ODg4qDg4ODg4ODg4ODg4ODg4ODg4ODioOKw4rDisOKg4ODg4ODg4rDisOKg4rDisODg4qDgAJlHM4Dg4OKw4ODg4ODg4ODg4ODQ4ODg4ODg4ODg4OKw4ODg4ODg4NDg4ODg4ODg4ODg4rDg4ODg4ODg0ODg4ODg4ODg4ODisOKg8qDisOKw4ODg4ODQ8qDisOKw4qDisODg4rDgANBQAAAAA’
This is my biggest code:
JgDwAA4ACHUAASyUFTcVNxQSFBEUEhURFRAVOBIUEjgUNxMTFBMTExMSExQSOBQ4FBEUOBITFBITExMTFBMSOBMUEhMVOBITEjgTExQTFBETExMTFBMSFBMSFRETExMTExIVEhQRFBMUERQSFAABCxISFBQSEhQSFBIUExQRFBIUEhMTFBITExQSExMUERQSFREUExMSFRITExITExMUEhQSExMUEhMTFBITEhQSFBMTEhQSFBIVERUSEhMTExMUFRATExMTFBIUEhMTExIVERQSFBITExQSFBIUExMSExUTOBQSExMTOBM4ExMUOBMSEwANBQAAAAAAAAAA
It is from an A/C Cold 23 degrees command.
Most of my IR codes are half of this and all my working RF codes are 1/4 of this…
