It seems that sp3 is supported: https://github.com/mjg59/python-broadlink/blob/master/broadlink/init.py#L18
Great!
Is there already a way to use SP1, SP2 or SP3, once they report their status…
I think Sp2 and sp3 will report the current state back to HA, but sp1 will not.
@undef : could you try to add your sp3 switch as:
type: sp2
I have a SP Mini.
Would be
type: SPMini
Should also be sp2: https://github.com/mjg59/python-broadlink/blob/master/broadlink/init.py#L16
Notice, that you will need the newest version: https://github.com/home-assistant/home-assistant/pull/5022
I will will add support for all the types later
The log not show any problem…
for you problem try to copy cp -r /usr/local/lib/python2.7/dist-packages/Crypto /usr/local/lib/python3.5/dist-packages/
How do I config complete A/C remote with all the buttons needed?
Thanks.
That will be a really challenge…
First of all, I think is time we ask for a Button Instance instead of using switches.
I think the best option would be creating a floating remote filled with buttons, just like the history floating window when click on a component on frontend.
It did not work.
Got a persistent notification saying Invalid Config
switch 3:
platform: broadlink
host: 192.168.1.207
mac: 'B4:43:0D:XX:XX:XX'
type: sp2
switches:
sp_switch:
Remove the two last lines
I did it, but now nothing appears on frontend…
Check your log
Thanks I did this (I had to change to python3.4 I hope it will work as well
A new version is ready for testing: https://github.com/home-assistant/home-assistant/blob/Broadlink_fix/homeassistant/components/switch/broadlink.py
nothing logged.
Check the output from hass --script check_config
Nothing as well…
(hass_venv) hass@pi:/home/pi$ hass --script check_config
Testing configuration at /home/hass/.homeassistant
hi daniel, i’m running into some issues just trying to get hass working with your latest file
(https://raw.githubusercontent.com/home-assistant/home-assistant/645cbff3f5c47acf996e40101f96a879c8ce9328/homeassistant/components/switch/broadlink.py)
here’s what I did:
pip3 install --upgrade homeassistant
removed the previous broadlink.py from custom_components/sensor
added the broadlink.py reference above in custom_components/switch
on starting hass it tried to fetch your dependency and failed with this error:
INFO:homeassistant.util.package:Attempting install of https://github.com/Danielhiversen/python-broadlink/archive/master.zip#master==0.3
Command “C:\Users\admin\AppData\Local\Programs\Python\Python35\python.exe -u -c “import setuptools, tokenize;file=‘C:\Users\admin\AppData\Local\Temp\pip-build-fspdk4ql\pycrypto\setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record C:\Users\admin\AppData\Local\Temp\pip-vr_c01xq-record\install-record.txt --single-version-externally-managed --compile --home=C:\Users\admin\AppData\Local\Temp\tmp5go0njn_” failed with error code 1 in C:\Users\admin\AppData\Local\Temp\pip-build-fspdk4ql\pycrypto\
So, would love to try out with my SP3 (SPCC) but need some help getting there.
— update
i manually placed the broadlink from your github under deps/broadlink/init,py (overwriting the 0.2 that came with the upgrade) and replaced the dependency wth broadlink==0.2.
the good news is the A1 still works… the SPCC remains silent, with nothing in the logs.
hope this helps in making sense of the behaviour.
I also try this
switch 1:
** platform: broadlink**
** host: 192.168.0.109**
** mac: ‘B4:43:0D:CB:FB:6F’**
** type: sp2**
** switches:**
** sp_switch:**
and get Invalid config error, any help???
What do you mean with that? Is the switch not showing up in the ui?
Try:
switch:
platform: broadlink
host: IP_ADDRESS
mac: 'MAC_ADDRESS'
type: sp2
switches:
Name:
