AUTO POWER
JgBQAJSPEQ4RDhMMEQ4SLhAvEg0RDhIvEDAQLxEvEQ0SDREPEA4SkBAPEQ4SDREOES4REBANEi8QLhEvEi4SDhAOES8RLhINEQ4REA8QDy8SAA0FAAAAAAAAAAA=
AUTO POWER
JgBQAJSOEg8SDxIPEREQLxIvERARDxIvES8SLxMuERATDRMOEREQkREvEw4SDxIQEC8SDxIPEi4TLhIwES4SEhEPES8TLhEREA8SEBIOES8SAA0FAAAAAAAAAAA=
POWER
JgBQAJGQEQ4REA8OEQ8QLxIuEg0RDxEuES4RLxEwEA4RDhINEQ4RkBINEQ4REA8OEg0RDxAOEg4QLxEvEC8RDxEuEi4RLhEvEg4QDhEPES4SAA0FAAAAAAAAAAA=
INPUT BD DVD
JgBsAFE9DSQMJQ4MDAoOCw4LDSQNCw0lDiMOCw0LDSYNCw4jDQsPIg4LDgoNCw4LDgwMDAwLDgoOCw0lDAsODA4JDgwNCg0LDyMNCw4lDAwOCg0kDgwOCQ8iDgsNCw4lDQoNDA0LDgAFZlBrDQANBQAAAAAAAAAAAAAAAA==
INPUT CD
+DSMOJA4KDQwNCw0LDiQOCw0lDSMOCw0LDiQNDQ0iDwsMJA8KDwkNDA0LDQsOCw0MDAwOCg0kDwoNCw8KDQsPCQ4LDSQNDQ0kDQoOJA0lDQwMDQ0KDSUNDA0lDAoOCw8JDQAFaFFsDAANBQAAAAAAAAAAAAAAAA==
INPUT GAME
JgBsAFE8DyMNJQ0LDgoODAwLDiMOCw8iDyMOCg4LDSQOCw4lDQoNJA4KDgsNCw4LDQsOCw4KDgoOCg8kDgoOCg0NDQkPCg0NDCQNCw0mDgkOJA4KDwoNDA4JDgoOCw0mDQoPCQ8JDgAFaFBqDwANBQAAAAAAAAAAAAAAAA==
INPUT IPOD
JgBsAFA9DSUOJQwKDgsNCw4KDiUMDA4jDSQOCw0LDiUMCw4lDAsOJQwLDgsOCg0LDgoPCwwLDgwMDA0jDgsOCg4LDQsNCw4lDCQPCw0jDgwNCg4LDgoNJgwlDSQNJA8jDQwNCg4MDAAFaFFpDQANBQAAAAAAAAAAAAAAAA==
INPUT SAT
JgBsAFI7DiUNIw8KDgoOCg4MDCYMCw0lDiMNCw0LDiQPCg0kDQsOJA0MDQwMDA0LDQsNCw4LDQsNDQwkDgoPCg4KDQsOCg8LDSQOCg0kDiQNJQ4jDgoOJA0LDyMNDQwlDgkOCw0LDwAFZFJpDQANBQAAAAAAAAAAAAAAAA==
INPUT TUNER
JgBsAFE9DiQNJA4MDQoNCw4MDCUNCg4kDSYMDA0LDSQNCw4lDAsPIw0LDgsPCQ0MDgoNDAwNDAwNCg4kDQsOCg8KDQsOCw0lDSQOCg8jDQwNIw4LDQsPIw8KDgkPCwwmDAwMCw8LDAAFalJsDAANBQAAAAAAAAAAAAAAAA==
INPUT TV
JgBsAFA9DiQNJA8LDAwMDA0KECMMDA0lDSQNDA0KDiQNCw4kDQsOJA0LDwkPCg0MDQsNCw0MDgoNCw4kDgoNDA0LDQwNCw0LDiQNCw0lDQsNJA0MDQsPCg0LDQsNCw4kDQsPCg0MDAAFaFBsDgANBQAAAAAAAAAAAAAAAA==
INPUT VCR AUX
JgBsAFA8DiQNJA4LDwkOCw0LDSQOCw4jDiQNDQ0KDiMOCw0lDgsMJA4KDgsPCg0LDQsNDA0MDQoNCw4lDwgOCw0LDgoOCw4jDiQOCg4kDSQODAwlDQwMDA0LDSUMCw4lDQoPCwwMDgAFZVFpDgANBQAAAAAAAAAAAAAAAA==
Found this on web:
“There aren’t any descrete codes. I found that if you put the sound bar on auto power, it will turn on itself. This can only be done by using an optical cable out of the TV into the sound bar. Once it senses audio, it will turn on automatically. The sound bar will turn off itself after 20 mins of no audio”
What would be the steps to create a database with IR codes and access them directly from the HA web interface.
I ask this because I just found out that a Universal Remote Control app for Android added RM-PRO support.
The application allows you to add an RM-PRO and configure any existing remote control in its database, which is very, very complete.
It would be great if we could eliminate the need for lerning.
Is it any chance to add a feature that the Broadlink could read IR input all the time and update switch devices when a IR device is switched from a remote?
My devices are using the same code to turn on and off so a automation rule is not very usefull since the automation rule don’t know if the device is on or off.
Just noticed now that one of my RM-PRO has the same problem, learning just those AAAAA
Now I will try the new version for broadlink.py @Danielhiversen created…
Fixed with the last version.
I have done some testing and it seems like the Broadlink could send and receive IR packages at the same time, I put it in learning mode and then tried to turn on a device from HA and the device turned on and Broadlink received a packet.
So if the Broadlink device is in learning mode all the time it should be capable to receive packages from a remote control, and also update the status.
Another advance I can see in have the Broadlink to receive packages is that you could actually use a IR remote control to turn on and off other devices that is connected to HA.
I am trying to configure the Broadlink Switch.
I updated to ver 0.35 of HA and tried to configure switch . I was able to make the RM Pro learn a switch initially but the issue was the switch was not coming on my Frontend.
I later changed the broadlink.py in both :/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/sensor and :/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/switch to the latest version .
Once the new versions of broadlink.py , I am getting the error " homeassistant.components.switch.broadlink: Failed to connect to device."
Kindly help:
To get the Switches on the frontend
To use the latest broadlink.py ( since i have a RMPro and IR Blaster)
My Configuration.yaml is as follows:
homeassistant:
Name of the location where Home Assistant is running
Location required to calculate the time the sun rises and sets
latitude: XXXXX
longitude: XXXXX
Impacts weather/sunrise data (altitude above sea level in meters)
So, I managed to install pycrypto manually under virtual env and I got the RM2 temp sensor showing on my HA frontend. But now trying to create switches I can’t get broadlink to show under domains to be able to use the learn_command. I’m sure I’m missing something.
Also… @oliverdog (boas ), can you get me the discrete codes for a 2016 Samsung Smart TV (KS7000)? Just paste it on a pastebin or something. Thanks mate!
Edit: nevermind… suddenly the learn_command is showing. Should have posted earlier.
