Can a Broadlink RM Pro be used as an RF receiver to pass a received signal to HA which will then be used to do some other action in response?
I looked in to this a while a go, simple answer - No it can’t.
Simon
well…that sucks…
Thanks for the reply tho.
I guess I should have followed that up with…
Did you ever figure out a way to read in RF codes to Home Assistant?
Basically what I want to do is read in a, for instance, fan remote so I can update the status of the fan in HA. Since there is no feedback from the device there is no way of knowing if it was turned on from the original remote bypassing HA.
If anyone has a better way of doing that I’m all ears (or eyes in this case…)
