Raspi AIO installed. HA updated to 0.47.1. getting temperature info from RM PRO. But RM PRO switches doesnt loading.
I’m getting this error:
ERROR (MainThread) [homeassistant.components.switch] Error while setting up platform broadlink
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 161, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
File "/usr/lib/python3.4/asyncio/tasks.py", line 372, in wait_for
return fut.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/switch/broadlink.py", line 133, in setup_platform
device_config.get(CONF_COMMAND_OFF)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/switch/broadlink.py", line 159, in __init__
self._command_on = b64decode(command_on) if command_on else None
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/base64.py", line 90, in b64decode
return binascii.a2b_base64(s)
binascii.Error: Incorrect padding
Any advice?
Thank you
