Hi someone knows where i can find Discrete Codes for the TV Hisense H39N2110C?
(Yep, i already google it and I found a couple of sites but the only list of codes that I found doesn’t work)
So, i have a Broadlink working, but only with the codes learned from the remote. The downside is for automations the toggle ON/OFF buttons isn’t enough…
I need the actual code for turn it OFF.
TV (Hisense H39N2110C)
Remote (ER-22601A)
IRBlaster: BroadLink RM mini 3
Yes to all the points, the issue is the remote button Power have 2 purpose, but i want only one.
For automation purpose, if I press the power button (via the send command) and the TV is already off, the command will turn it on.
I have a work around for it, have a ping sensor to have a condition on the script. But I would like to see a command only for turnoff, but the remote doesn’t have it. So I can’t learn it.
The actual question is if someone knows where I can find that IR code to turn it into a base64 and get rid of the ping sensor.
Yep, I tried but without luck.
I found a list of codes from Hisense itself, but the codes didn’t work… Maybe because of the TV models, mine is recent but the file is 5 years old.
RemoteCentral and IRDb and they don’t have my TV.
I tried reaching the Hisense’s support because it’s a recent TV. I’m not sure what should be my hopes for Hisense’s response but I only sent the email yesterday.
I have a workaround by using the ping sensor, but… I would like to see it properly configured.
I explained what was the situation and they replied that the codes that they have the are the same on the PDF. So no Luck… But the response was quick thought…
[Lang: PT-PT]
Boa tarde:
Caro cliente, os códigos que você possui são os mesmos que temos nós.
Lamentamos não poder dar-lhe outra solução.
Com os melhores cumplimentos.
Atentamente. Best Regards
EQUIPO SOPORTE - Teléfono: — — —
[REDACTED_EMAIL]@hisenseiberia.com
Hisense Iberia, S.L.U.
As a workaround I manage to find the current state of the TV via Chromecast powered via USB Port.
Suggestion from Discord #general channel.
Kudos for the guy that mention that some people do it like that.
