I am a newbie with home assistant and I got so much fun to develop and automate some stuffs in my home. One of the problem I am facing is that I cannot connect with my broadlink rm. When I use developer tool to trigger the service request, i got this in the terminal log.
17-03-16 08:29:27 ERROR (MainThread) [homeassistant.components.switch.broadlink] Failed
to connect to device, timeout.
Not sure if related, but the MAC you have supplied is registered to Jorjin technologies.
I checked my MAC for my broadlink and it is correct labelled under Broadlink Pty Ltd.
It might be worth double checking the MAC/IP again, try pinging the broadlink and power it off … does the ping stop or continue?
Be honest, I have bought this product long time ago and broadlink yet appeared on international market. The one I am holding is like the first generation device.
If somewhat that’s the reason, I will consider to buy a new one
I’m also experiencing the same issue. Total n00b, sorry. Can anybody advise how to go about applying the fix to my local library please (I’m using Hass.io)? I have Googled much without success…
My hardware - RP3, HA 0.63.1 (Hassbian and Raspbian), Python 3.5.4, Broadlink Devices.
I try to upgrade/install Python 3.6.4 due to the soon of breaking change for python support in HA.
The upgrade was successfully to 3.6.4. However, Once restart and load HA, I lost all my broadlink switches and whatever regarding with broadlink, did not show up on frontend with no error.
