Hi guys
Just wondering if this would be possible and how would I go about doing it?
I’ve got everything setup locally just fine but wanting to move to a VPS and use Docker.
Kind Regards,
Adrian
Hi guys
Kind Regards,
Adrian
I think you will have to set a VPN server on your local-network, then set your VPS to connect to your home local network. This way they will be in the same “network”.
However, even if this is a solution to make it work, you will have to get a server running on your local-network to enable this VPN connection. So, why not directly run HA on this local server ?
Ahh I thought as much.
It’s just a thought I have and would like to do. There will be a PC that the VPN could run on but yes not ideal overall.
