I have integrated a Broadlink RM3-mini into HA. But it shows me only one entity: Remote RM3-mini. How can I steer my aircondition which is conected to the remote RM-3 mini? I just need a switch to start and stop the AC. Thanks,
Holger
Holger
First you have to learn the codes, using service calls. Then you ultimately use service calls to send the codes that you’ve learned. It’s not the most obvious process, but not bad (and doesn’t take much time if only learning a handful of codes).
As far as translating that into a switch, you have options. Could use a helper and an automation or a template switch.
