Broadlink Rm4 mini integration
I bought a Broadlink rm4 mini (I already have two perfectly integrated rm3 mini).
I added the device to the app, configured the wifi with fixed ip, and disabled the lock.
However, the integration is not detected, trying to enter it manually with the ip address I get: device not supported.
How can I solve?
Thx
strange, it has to work. I’m running two of the rm4 mini’s simultaneously here…
Have you seen the updates to the way the manual code is supposed to be written? I had to rewrite all of mine to match the new format…I have 5 of them.
No, how can i do It?
I have 5 of them too, all integrated flawlessly through config-flow of the Broadlink Integration. Same as BebeMischa they all just work. What Firmware is installed? It’s 52078 here.
Well, its a newer Firmware (6.x vs. 5.x) if that matters.
You have installed the Broadlink Integration and removed all Broadlink config entries from configuration.yaml, have you?
yes, I have two other rm3 integrated without any problem
Please post what the HA logfile is exactly saying when you try to add your new RM4 mini (the error message only is not enough).
Dettagli registro (ERRORE)
Logger: homeassistant.components.broadlink.config_flow
Source: components/broadlink/config_flow.py:38
Integration: Broadlink (documentation, issues)
First occurred: 8 marzo 2022, 21:32:20 (9 occurrences)
Last logged: 07:57:19
Unsupported device: 0x5216. If it worked before, please open an issue at Issues · home-assistant/core · GitHub
Well, 0x5216 is not supported yet. Thus you should open an issue at GitHub.
