He comprado un Broadlink RM4 Pro y cuando intento realizar la integracion con Hassio me dice:
Abortado
Dispositivo no compatible
Alguien me puede ayudar ?
RM4 Pro is compatible with hassio
Como evito que me salga el error ?
There are multiple devices sold as RM4 Pro, the newer one is pending support. See this ticket: https://github.com/home-assistant/core/issues/40191
There is some Python code you can run that will extract the device code, you can then see if your one matches the new model. The code is in the ticket comments.
