I had my broadlink remote set up with different commands and everything was working fine until recently. Not sure how long ago it stopped working because sometimes I don’t use any commands for 2 months. I get this error when I try to use any remote service call in dev tools
“Failed to call service remote.delete_command. trailing comma is not allowed: line 12 column 6 (char 783)”
I tried removing the comma but then I get an error for a different comma and then another and so on. I then read somewhere not to mess with the file so I returned it to how it was. I tried removing the device and re adding but the .storage file with the remote codes remained so it just gives the same errors. Is there a way to start again or an obvious fix to the code?
Here is my code at /config/.storage/broadlink_remote_<*********>_codes:
"version": 1,
"minor_version": 1,
"key": "broadlink_remote_*********_codes",
"data": {
"Living Room TV": {
"PS5": "JgBQAAABIZATERMSEhISExETEhISEhMREzYSNxI2EzYSNxI2EzYRNxI3EjYSNhMSEzYSEhITERMSEhISExETNhITETcSOBE2EgAE8QABIUkTAA0F",
"Xbox 360": "JgBMABETEhMREhMRExITERMSERMSNhM2EzYSNhI3ETYTNhM2EhMRNxISExETNhISEhITEhI2EhMSNhM2EhISNhM2EzYRAATxAAEhSRMADQU=",
"Chromecast": "JgBQAAABIZATEhISExETEhISEhMSERMSEjcSNhI2EzYSNxI2EzYSNhM2EhITEhE3EjYTEhM2EhETEhI3EjYSEhMREzYTEhE3EgAE8QABI0cSAA0F",
"Cameras": "JgBIAAABIpASEhMRExITERITERITEhISEzYSNxI2EjcRNxI2EzYSNxISEhITERM2EhMREhMSEhITNhI3EjYSEhM2EjYTNhI3EQANBQ==",
"Xbox_360": "JgBQAAABIZESEhISExETEhISExISEhITETYTNhM2EjYTNhM2EjYSNxISEjcSERMSEzYSEhITERMSNhMREzYSNhMSEjcSNhI2EwAE8AABIkkTAA0F",
"Bedroom TV": {
"Cameras": "JgBYAAQAC00GAAIqAAEikBISExETEhISExIRExITERITNhM2EjYSNxI2EjYTNhM2EjYTNhISEhMSERMSEhITEhISEhMRNhM2EzYSNhM2EzYSAATwAAEiSRIADQU=",
"Chromecast": "JgBQAAABIZESEhMREhMSEhISExETEhISEjcSNhM2EjYTNhM2ETcSNxI2EhMSNhMRExIRExITERITEhI2EhMSNhM2EjcRNxI2EwAE8QABIkgSAA0F",
"Xbox 360": "JgBMABISEhITEhISExESExISEhITNhI3ETcSNxI2EjYTNhM2EhMRNxI2EhMSEhISExETEhI3ERMSEhI2EzYSNhM2EzYSAATyAAEhSBMADQU=",
"PS5": "JgBgAAABIpASExISEhISEhMSEhITERMSEjYTNhI3ETcSNhM2EjYTNhMSEjYSNhM2EzYSEhI3EhITNhIRExISEhMSEjcRExI2EwAE8AABIkkSAAwEAAEiSREADAQAASNJEQANBQ==",
"Xbox_360": "JgBQAAABIZATEhISExETEhISEhMSERMSEjcSNhI2EzYTNhI2EzYTNhETEjYTNhISEhMSEhISEhITNhISEhMSNhM2EjcRNhM2EwAE8AABIkkSAA0F"
