for the second RM4 Pro added via Broadlink integration I’ve been trying to call send_command service for RF and IR. Unfortunatelly when trying to call a service remote.send_command I receive the following error:
Expecting property name enclosed in double quotes: line ... column ... (char ...)
no matter what command I try to send.
The device seems to be connected properly (I tried reconnecting add the Broadlink devices by removing the integration completely and then adding all of them again). The stats are visible and entities are accessable (humidity, temperature, remote set to on).
The first RM4 Pro works perfectly fine, but the second one gives the abovementioned error (works all right via the application, the device is unlocked also).
I don’t know how to handle this problem. Can anybody help?
Best regards
