@ywjlost
Yeah there’s been a breaking change in 0.88.0,
The folder structure of the custom_components folder has changed.
Please have a look in the component’s repository, I already made the adjustments.
You can read about the change itself here.
@ywjlost
Broadlink has updated the S1C to the S2, i will try your library once that arrives but I fear we might need an update^^
it works from early version, I tested more then 7/8 month ago
All working on 0.91.2
Hi guys, i have this error with my sensor after update Hassio from 0.90 to 0.91.2
File “/config/custom_components/broadlink_s1c/sensor.py”, line 259, in run current_status = self._hub.get_sensors_status() File “/usr/local/lib/python3.7/site-packages/broadlink/init.py”, line 782, in get_sensors_status response = self.send_packet(0x6a, packet) File “/usr/local/lib/python3.7/site-packages/broadlink/init.py”, line 305, in send_packet response = self.cs.recvfrom(2048) socket.timeout: timed out
Please help me…
Hi, I try to work with that but after that I save the change in the configuration I try to run configuration check and it’s never finish it.
there is an option to fix it?
That’s a network issue my friend.
Can you share the logs please?
Hi I didn’t get the log cause it’s stuck in the configuration check (loading but nothing append)
I have this problem sometimes wrong information from this custom components. I have many timeouts
HA 0.91.4
Sat Apr 20 2019 15:05:54 GMT+0200 (CEST)
exception while getting sensors status: Traceback (most recent call last):
File "/config/custom_components/broadlink_s1c/sensor.py", line 259, in run
File "/usr/local/lib/python3.7/site-packages/broadlink/__init__.py", line 782, in get_sensors_status
File "/usr/local/lib/python3.7/site-packages/broadlink/__init__.py", line 305, in send_packet
After upgrade so many timeouts Maybe something strange i’m not the only who have this problem, can you check if there is a solution ?
Hi, I have a problem when I uploaded de 0.92.0 version, I dont understand where is the problem, in de old version 0.91.4, the s1c sensor the run was ok.
Make an __init__.py
in your /config/custom_components/broadlink_s1c/ folder, if it doesn’t exist.
And create a manifest.json
file with the following content:
"domain": "broadlink_s1c",
"name": "Broadlink S1C",
"documentation": "https://github.com/TomerFi/home-assistant-custom-components/tree/master/broadlink_s1c",
"dependencies": [],
"codeowners": [],
"requirements": []
I have the .ini file and I make the manifest.json file with the same text that it explains, and the problem is the same, I do not know where the problem is.
I do not know what I failed. I’m not a programmer, and I ask for patience, I’m sorry.
No problem. Did you check the logs?
I check the log and it just says:
2019-04-26 23:29:53 ERROR (MainThread) [homeassistant.components.hassio] Integration broadlink_s1c not found when trying to verify its sensor platform.
My configuration.yaml
#S1C broadlink
Thank you for your time
I had that error, but after adding the empty file __init__.py
and manifest.json
in the folder custom_components/{your_platform}
with content like this:
"domain": "your_domain_name",
"name": "Your Integration",
"documentation": "https://www.example.com",
"dependencies": [],
"codeowners": [],
"requirements": []
The component worked again.
Now it’s OK!!!
I had the manifest.json in the custom_components folder, I have change in bloadlink_s1c folder and now is running perfectly…
Thanks for your attention.
Best regards
Since I’ve HA version 0.88 and before to upgrade to last HA 0.95, I ask you if someone has updated its HA to 0.95 and this very nice component works.
I’ve upgraded to 0.95.4, everything seems to be working the same.
I have sometimes this custom components not working perfect, sometimes give wrong information on status of sensor, I have 5 s2c hub and 1 s1c with lot of sensor, but sometimes I have a timeout warning and a sensor or 2 give wrong status.
File "/usr/local/lib/python3.7/site-packages/broadlink/__init__.py", line 809, in get_sensors_status
File "/usr/local/lib/python3.7/site-packages/broadlink/__init__.py", line 298, in send_packet
what can I do to minimize the timed out ?
I need to restart HA and all came back to normality. Could be implemented a guard option that restart only the custom component if timed out?
