Broadlink S3 Hub & Aqara Devices
Hi all,
Noobie here so go easy :slight_smile:
Im after some help to get my Broalink WiFi wall switches into home assistant.
Currently the area i am after has Broadlnk Switches but however as its a 2 way switch (Hall way and stair case) they are having issues. I am doing the 2 way switching via scenes and they work 50% of the time, just some times they are not responding as they should unless i reboot the S3 hub.
My setup looks like this:
Switch 1 - Broadlink TC 1 gang switch controlling landing. Live powers below switch.
Switch 2 - Broadlink TC 2 gang switch controlling hall and landing.
Switch 3 - Broadlink TC 2 gang switch controlling hall and controls a BG socket under stair case for staircase.
Problem is if i go to Aqara (which i am considering) i will lose the socket control or the hall control.
So i could use a really noob friendly way of getting broadlink devices to talk with either home assistant
This is a place to post requests for new Home assistant software features.
I suggest you change the topic to remove feature request, and add configuration topic, and add the tag hardware.
That should put the question where the right people will see it.
