BroadLink S3 hub
Will there ever be support for the BroadLink S3 hub? All my light switches use the S3 hub and home assistant does not find it. Any help appreciated. Thank you
Any help would be much appreciated
It looks like the S3 hub is supported by the latest version of python-broadlink, which has been in home assistant core since late May of this year. I can confirm that python-broadlink version 0.18.2 running on my computer can speak to the hub and see the appropriate TC3 switches i have. The broadlink integration, however, says the device is unsupported. I think only some minor updates would be needed to get it working in HA at this point, but i’m not sure what they are.
Thank you for that. I’ll see if I can get it to work.
Any luck with this? Will it work with the LC1-3 gang switch?
