Hey All,
Been using the Broadlink Integration for weeks now with no issues. I upgrade my Home Assistant version whenever there is a new one available.
All of a sudden, and I can’t figure out why, my Broadlink Commands aren’t working anymore?
Configuration Yaml:
switch:
- platform: broadlink
host: 192.168.1.142
mac: 'XX:XX:XX:XX:XX:XX'
timeout: 15
cover:
covers:
b_b3_1:
friendly_name: "Bedroom 3.1"
position_template: "50"
device_class: "shade"
open_cover:
service: broadlink.send
host: 192.168.1.142
packet:
- "data that worked previously"
close_cover:
host: 192.168.1.142
packet:
stop_cover:
host: 192.168.1.142
packet:
Causes Error:
Failed to call service cover/open_cover. Unable to find service broadlink/send
Alternative Configuration Yaml I have tried:
b_b1_0:
friendly_name: "Bedroom 1"
open_cover:
service: remote.send_command
host: 192.168.1.142
packet:
Causes Error:
Failed to call service cover/open_cover. extra keys not allowed @ data[‘host’]
HA Logs:
020-07-12 22:30:56 WARNING (MainThread) [homeassistant.components.remote] Platform broadlink not ready yet. Retrying in 180 seconds.
2020-07-12 22:31:36 WARNING (MainThread) [homeassistant.components.switch] Setup of switch platform broadlink is taking over 10 seconds.
2020-07-12 22:31:41 WARNING (MainThread) [homeassistant.components.switch] Platform broadlink not ready yet. Retrying in 180 seconds.
2020-07-12 22:32:52 ERROR (MainThread) [homeassistant.helpers.script] Error executing script. Service not found for call_service at pos 1: Unable to find service broadlink/send
2020-07-12 22:32:54 ERROR (MainThread) [homeassistant.helpers.script] Error executing script. Invalid data for call_service at pos 1: extra keys not allowed @ data['host']
2020-07-12 22:32:54 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.1683226960] extra keys not allowed @ data['host']
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 130, in handle_call_service
connection.context(msg),
File "/usr/src/homeassistant/homeassistant/core.py", line 1260, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1295, in _execute_service
await handler.func(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 209, in handle_service
self._platforms.values(), func, call, required_features
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 454, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 595, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 485, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/template/cover.py", line 318, in async_open_cover
await self._open_script.async_run(context=self._context)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 831, in async_run
await run.async_run()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 555, in async_run
await self._async_run()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 572, in _async_run
await self._async_step(log_exceptions=not propagate_exceptions)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 153, in _async_step
self, f"_async_{cv.determine_script_action(self._action)}_step"
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 656, in _async_call_service_step
*self._prep_call_service_step(), blocking=True, context=self._context
File "/usr/src/homeassistant/homeassistant/core.py", line 1222, in async_call
processed_data = handler.schema(service_data)
File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 208, in __call__
return self._exec((Schema(val) for val in self.validators), v)
File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 287, in _exec
raise e if self.msg is None else AllInvalid(self.msg, path=path)
File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 283, in _exec
v = func(v)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 817, in validate_callable
return schema(data)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 432, in validate_mapping
raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: extra keys not allowed @ data['host']
2020-07-12 22:32:57 ERROR (MainThread) [homeassistant.helpers.script] Error executing script. Service not found for call_service at pos 1: Unable to find service broadlink/send
