Broadlink Switch unique ID issue
Hey, I’m trying to setup my broadlink RM4 mini with a couple devices as switches but when i look under entities they show up as read-only due to missing unique ID.
I have friendly names setup but cannot set unique ID for the switches so unsure what i need to do
My config is shown below
switch:
 - platform: broadlink
   host: 192.168.20.17
   mac: 24:DF:A7:34:BB:EA
   timeout: 15
   switches:
     aircon_remote:
       friendly_name: "Air Con"
       command_on: 'JgCSAAABJJMWEhUSFxEVEhYSFRIWEhUSFjYWERYSFjYWERYSFRIWEhUSFhIVEhYSFRIWNhcRFRIWEhUSFhIVEhY2FxAWNhYSFhEWNhUSFgACkBUSFhIVEhYSFRIWEhUSFhIVEhY2FhIVEhYSFRIWEhUSFhIVEhYSFhEWEhYRFhIWEhUSFhIVEhYSFjUWNhYRFhIWAA0FAAAAAA=='
       command_off: 'JgCSAAABJpEWEhcRFhEWNhYRFhIWERYSFjYVEhYSFTYWEhYRFhIVEhYSFRIWEhYRFhIWNhYRFhIWERYSFRIWEhU2FhIWNRcRFhIVNhYSFgACjhcRFRIWEhYRFhIWEhUSFhIVEhY2FhEWEhYRFhIWEhUSFhIVEhYSFRIWEhYRFhIWERYSFhEWEhYSFTYWNhYRFjYWAA0FAAAAAA=='
     tv_remote:
       friendly_name: "TV"
       command_on: 'JgBGAJOTEjcSNxI3EhISEhISEhISEhI3EjcSNxISEhISEhISEhISEhI3EhISEhISEhISEhISEjcSEhI3EjcSNxI3EjcSNxIABfgNBQ=='
       command_off: 'JgBGAJOTEjcSNxI3EhISEhISEhISEhI3EjcSNxISEhISEhISEhISEhI3EhISEhISEhISEhISEjcSEhI3EjcSNxI3EjcSNxIABfgNBQ=='
unique_id is not implemented for broadlink (it must be done in code), so there’s nothing you can do from your configuration to fix that I’m afraid.
Damn, I can use scripts to get by for now.
Do you know if there are currently plans to fix this? I’ve got quite a few devices I’d like to control through Broadlink + switches
What do you need the unique_id for ?
To toggle the state, without a unique ID its read-only
The unique_id has nothing to do with the state ? States are toggled by the enitity_id.
You were right after taking another look at the logs i had another error (Failed to send packet: The device storage is full), after defining the device type to fix this i can now toggle the device properly
The unique id is only used by Home Assiatant to map a device to a configuration, so you can change for instance friendly name or entity id. It doesn’t affect functionality of the integration otherwise (as already mentioned). There is however a PR open for adding config flow for broadlink, which adds unique id since that is needed for config flows. So it will come.
For switches it unfortunately stayed the same after this PR, so this feature is still wanted.
Sorry to ressurect the thread, but is it at all possible to add a unique_id (so i can set a room etc.) to a ‘switch’ that uses the Broadlink platform to send the RF command to turn the switch on and off? At the moment i have the switch working and showing up in the main UI however as it doesnt have a unique_id it cant be assigned to a room… anyone have a trick to doing it?
Hello everyone!
It seems that unique_id management is still not yet functional for switches. Is there a way to do add one in order to manage yaml-added-switches from the UI?
Unique_id management would allow me to add those switches to a room via the GUI and associate some labels. This would be a big plus.
The code could look like this in yaml
    mac: 'AA:BB:CC:DD:44:55'
    switches:
      - name: 'Ampli'
        command_on: 'XXXXXXXXXXXXXX'
        command_off: 'YYYYYYYYYYYYYYY'
        unique_id: b3a3dfb26-c32836a092c6=
I can open a request on github if needed.
I vote for this feature too.
