Broadlink wifi bulb LB1 with hass
@KTibow whenever I try to add one of rhe bulbs in the Broadlink HA, it does not work, stating “Device not supported”
Did you try to look in the open issues yet?
I tried, however I did not see anything relevant. A simple play in PyCharm, and I can do this. But not enough to get it to HA and integrate it:
import broadlink
devices = broadlink.discover(timeout=5)
user_input= input('Turn the light on ?')
bulbs = []
for device in devices:
    if device.get_type() == 'LB1':
       bulbs.append(device)
for element in bulbs:
    element.auth()
    status = element.get_state()
    if user_input == 'yes' and status['pwr'] == 0:
        element.set_state(pwr=1, brightness=100)
    else:
        element.set_state(pwr=0, brightness=100)
Any update to this thread? I have a smart bulb from aliexpress and the python-broadlink module recognize it as LB1 and it works well with the module.
If there’s no work being done, I want to make a custom component or pull req. for a ha core component.
I actually implemented support for LB1 in the official broadlink integration on home assistant core. You can find another thread about this here: "LED Light bulb" with Magic Home app" integration? - #53 by new-kirte
and the pull request to add support here:
https://github.com/home-assistant/core/pull/50953
Currently, it does only support full RGB LB1.
What a good news! I’ll go try it right away
I am re-opening the discussion - can anyone tell me if you have managed to add more than 1 LB using the Broadlink integration?
I have managed to add the first LB, but for the second, third, and so on, it states that the device is already configured. I have 4 LBs that I would like to add to HA, but besides 1, I cannot add any of the other.
Any help would be appreciated.
On your router, try assigning static IPs to your bulbs. Then add them manually
