Broardlink IR Learning issue
Hi Guys,
I am trying to learn a code for “Power” on my Foxtel IQ2 remote (PayTV).
It seems that every time I press the button a new code is captured !?
EG:
JgAeAA4GBmEFAAxKGwAMrw4GBtQFAAtyDQcGAAEzEwANBQAAAAAAAAAAAAA==
JgAoAA4GFwABJwYAC5AOBweIBKsFAAuRDgYGDAUADL4OBgYADM4OBwYADQU=
JgAuABskBDgFFAVBBCkFNwUAC6EbYAUUBUEEKQU3EwALkxskBTcFFAUyBRUEZQUADQUAAAAAAAAAAAAA
I have even tried programming my universal remote… and sent the commands with it.
Same result.
Codes are listed here: http://irdb.tk/codes/ and here: https://github.com/probonopd/irdb/blob/master/codes/Foxtel/Unknown_foxtel/33%2C160.csv
Power = Nokia32 33 160 12
Any ideas how to turn “Power Nokia32 33 160 12” into the Base64 string?
That way I can avoid trying to capture and replay.
Thoughts?
base64 would look like this
Tm9raWEzMgkzMwkxNjAJMTI=
here is a site I use for these conversions Base64Decode
thanks Jim. It is a bit more complex than just converting the string.
The String I listed is a shorthand way that is used to describe the protocol. (OBC = Original Button Code)
Protocol Nokia32, device 33, subdevice 160, OBC 12
Data like this is often used by the JP1 and Pronto communities to classify IR codes.
It seems that I can use the ‘Foxtel IQ2’ codes and program my universal remote… however every time that I attempt to use the Broardlink to capture them they are different!?
I was trying to find a reliable way to convert straight into the Base64 string.
I might see if the JP1 forum has any tools (or more clues).
By the way, if anyone is looking for discrete codes for On/Off then the JP1 files section has a library devices. I used these files to program my Universal, then captured with Broardlink.
EG:
  • platform: broadlink #Lounge
    host: 192.168.168.151
    mac: “78:0f:77:00:79:74”
    timeout: 15
    type: rm_mini
    switches:
    lounge_panasonic_tv:
    friendly_name: “TV Power”
    command_on: ‘JgAyAXI5Dw4OKw4PDQ8ODw0PDg8ODw0PDg8NDw4PDQ8OLA0PDg8NDw4PDQ8ODw0PDg8ODw0sDg4ODw0PDg8ODw0PDg8NDw4PDSwOKw8qDyoPKw4ODg8NDw4sDisOKw4rDisPDg0sDgAJfnE6Dg8NLA0PDg8ODw0PDg8NDw4PDQ8ODw0PDg8OKw8ODQ8ODw0PDg8NEA0PDg8NDw4rDg8NDw4PDg8NDw4PDQ8ODw0PDiwNLA4rDisOKw8ODQ8ODw0sDyoPKg8rDisODg4sDgAJfXI6Dg4OLA4ODg8NDw4PDQ8ODw0PDg8ODw0PDg8NLA4ODg8NDw4PDg8NDw4PDQ8ODw0sDg8NDw4PDQ8ODw0PDg8NDw4PDisPKg4rDysOKw4ODg8ODw0sDisOKw8qDyoODw4rDgANBQAAAAAAAA==’
    command_off: ‘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’
    lounge_panasonic_tv_tv_input: #TV
    command_on: ‘JgDMAHI5Dw4PKg8ODg8NDw4PDQ8PDg8ODg4ODw4PDQ8PKg8ODw4ODg4PDg8NDw4PDg8ODg8qDw4OKw8ODg8NDw8ODg4PDg4PDQ8PDg4PDSwOKw8ODQ8ODw4rDw4ODg4sDisODw4rDgAJlnI5Dw4PKg8ODg8NDw8ODQ8ODw4PDQ8PDg8ODQ8OLA4ODw4NDw4PDg8ODg4PDQ8ODw8qDw4OKw8ODg8ODg4PDg4ODw4PDg4PDg0QDisOKw8ODg4ODw0sDw4ODg4sDisODw4rDgANBQAAAAAAAAAAAAAAAA==’
    lounge_panasonic_tv_amp_input: #HDMI2
    command_on: ‘JgAyAXE6Dg8NLA0PDg8ODg8PDQ8NDw4QDA8ODw4ODw8NKw4PDQ8ODw0QDQ8NEA4ODhANDg4rDw8MEA0sDQ8ODw4ODg8NEA0sDg4PDg0QDSwNLA0PDisOLA0PDisOEA0rDisPDg4PDQAJfnI6Dg4OKw8ODQ8ODw4PDRAMEQ0PDQ8NDw4PDRANLA4PDQ8NDw4PDRANDw0QDRAODwwsDg4PDg0sDg8NEA4ODRANEAwsDw4NDw8ODSwOKw4QDCwNLA4PDisODw0sDSwODhANDQAJf3E6Dg8NLA4ODg8NDw8PDQ4PDw4ODg4ODw0PDhANKw4PDg4OEAwQDQ8NDw8ODRAODw0rDg8NDw8qEA4NEA0PDRANDg8rDg4ODw0PDisOKw8ODisOKw4QDSsPDwwsDSwOEAwPDgANBQAAAAAAAA==’
    lounge_pioneer_amp_castaudio_input: #CD Input
    command_on: ‘JgAgAQABGIoTMxISEjMTERIREjQSERI0EhETMxIREjQSNBIREzMSEhIREhESNBI0EhESERI0EhISMxMzEhIREhI0EjQSERI0EgADbQABGIsSMxMREjQSERIREjQSERI0ExESMxMREjMTMxMREjMTERIREhESNBI0EhETERI0EhESNBIzExEREhI0EjQSERI0EgADbgABGIoSNBIREjQSERMREjQSERI0EhESNBESEjQSNBIREjQSERMREhESNBI0EhESERMzEhETMxI0EhETERE0EjQTERE0EwADbQABF4sTMxISEjMSEhIREjQSERI0EhETMxIREzMSNBIREzMSEhIRERISNBE1ERISERMzExESMxMzExESERI0EjQSERI0EgANBQAAAAAAAAAA==’
    lounge_pioneer_amp_kodi_input: #SAT/CBL
    command_on: ‘JgAgAQABGIoSNBESEjQSEhIREjQREhE1ERISNBESEjQSNBESEjQSERMREhESERMREjMTERIREhETMxI0EjQRNRIREjQSNBIzEwADbgABF4sSNBESEjQSERIREzMSEhIzExERNBMREjQSMxMREjQREhIREhISERESEjQSERMREhESNBI0EjMTMxMREjMTMxI0EgADbgABF4sSNBIREzMSERMRETQTERI0EhERNRIREjQSNBIREjQSERISERISERISEjMTERIREhETMxI0EjQSNBIRETUSNBIzEgADbgABF4sSNBIREjQSERMREjQSERI0ERIRNRESEjQSNBIREjQSERMREhESERISEjMTERESERISNBI0EjQSNBIREjQSNBE0EwANBQAAAAAAAAAA==’
    lounge_pioneer_amp_fox_input: #DVD
    command_on: ‘JgAgAQABF4sSNBIREjQSERESEjQSEhIzExESMxMREjQSMxMREjQSERI0EhESNBIREhIREhESEjQSERMzEhESNBMzEjQSNBIREgADbgABGIoTMxIREzMTERIREjQSERE1EhESNBIREjMTNBESEzMSEhE0ExESMxISERISERMREjQSERI0EhESNBI0EjMTMxMREgADbgABF4sSMxMRETUSERESEjQTEBMzEhIRNBMREjQRNBISETUREhI0EhESNBIREhESEhIREjQSERI0ERITMxI0EjQSNBIREQADbwABF4sSNBIREjQSERIREjQSERMzEhISMxMRETUSMxMRETUSERI0EhESNBIREhESEhIREjQSERI0EhETMxI0EjQRNRIREQANBQAAAAAAAAAA==’
    lounge_pioneer_amp:
    friendly_name: “Amp Power”
    command_on: ‘JgDYAAABGIsTMxIREjQSERIREjQREhIzEhESNBIREjQSMxMQEjQSERIREjQSERIzEzMSERIREhESNBIREjMTEBMQEzMSNBIzEwADRwABGIsSNBIREjQSERIREjMSERI0EhESNBIREjMSNBIREjQSERIRETQTEBI0EjQSERIREhESMxMQEzMSERIREjQSMxMzEgADRwABGYsSMxMQEjQSERIREjQSERIzExATMxIREjQSMxMQEzMSERIREjQSERIzEzMSERIREhESNBIREjQSERIQEzMSNBI0EgANBQ==’
    command_off: ‘JgAgAQABGIsSNBIREjQSERIREjMSERI0EhESNBIREjMTMxIREjIUERIzEzMSERI0EjMTEBMQExATEBMQEzMSERIREjQSMxMzEgADSAABGIsSNBIREjMTEBIREzMSERI0EhESMxMQEzMSNBIREjMTEBMzEjQSERIzEzMSERIREhESERIREjQSERIREjMTMxI0EgADRwABGIsTMxIREjQSERIREjMTEBMzEhESNBIREjQSMxIREjQSERI0EjMSERI0EjQSERIREhESERIREjMSERIREjQSNBIzEwADRwABGIsSNBIREjMTEBMQEzMSERI0EhESMxMQEzMSNBIREjMTEBMzEjQSERI0EjMSERIRExASERIREjQSERIREjMTMxI0EgANBQAAAAAAAAAA==’
