Hello. Day two of playing with my new Pi and I have broke it.
I was working through this guide:
https://www.juanmtech.com/home-assistant-hassos-beginners-guide#
And had successfully installed Hassio, configurator, samba and was installing and setting up DuckDNS when I have clearly run into trouble and I am too new to know what I have done.
I am getting all these errors:
Setup failed for ssl_key: Component not found.
10:07 PM setup.py (ERROR)
Unable to find component ssl_key
10:07 PM loader.py (ERROR)
Setup failed for api_password: Component not found.
Unable to find component api_password
Setup failed for base_url: Component not found.
Unable to find component base_url
Setup failed for ssl_certificate: Component not found.
Unable to find component ssl_certificate
Duckdns Configuration looks like this:
“lets_encrypt”: {
“accept_terms”: true,
“certfile”: “fullchain.pem”,
“keyfile”: “privkey.pem”
“token”: “MYTOKEN”,
“domains”: [
“MYDOMAIN.duckdns.org”
“seconds”: 300
And my config file looks like this:
http:
api_password: “MYPASSWORD”
base_url: MYDOMAIN.duckdns.org
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
adding the api password was a setup stage for Configurator but I have never seen a screen that’s asked me for it, so not sure if this has caused the issue.
I have setup port forwarding as far as I can tell.
My other thought is today is the first time using the Pi without the flash drive in which had the config for the wifi? but the pi is connected over ethernet, and I can load http://hassio.local:8123/ and access the configurator etc.
Sorry, I am sure this is something really simple but need some help
