System suggested an update, 80.1 I think, so I updated.
Now everything other than hassio and overview pages return “Error while loading this panel”.
I can still access the Configator through the webUI through the Addons panel.
I have no idea what to look at to solve the error(s).
System shows HassOS 1.9 and Supervisor is 137 all installed on a Pi 3.
Any help would be greatly appreciated!
might be worth mentioning what version you updated from and if you get any errors in the logs
I am guessing you didnt take a snapshot before the upgrade?
Have you rebooted?
I believe the version was .79.8. Log doesn’t show
as @nickrout mentioned have you tried a reboot of the Pi? If you have the Samba addon installed you may be able to see your logs in the config share
If you have ssh enabled you can also access logs with the hassio ha logs commands and hassio su logs for the supervisor logs (you should also be able to get to those logs if you have a screen and KB attached to the pi)
I don’t have either Samba or SSH installed
do you get anything if you go to
http://your-hassio-address:8123/dev-info or http://your-hassio-address:8123/hassio/system
there is normally some logs available on those
Also as was suggested above have you got a keyboard and screen attached to your Pi and have you tried rebooting
Pi has been rebooted, Hassio was rebooted and everything is the same “error loading this panel”.
Here is the log from the Hassio System panel;
18-10-16 01:59:53 INFO (MainThread) [main] Initialize Hass.io setup
18-10-16 01:59:53 INFO (MainThread) [main] Setup HassIO
18-10-16 01:59:53 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/armhf-hassio-supervisor with version 137
18-10-16 01:59:53 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1
18-10-16 01:59:54 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
18-10-16 01:59:54 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1
18-10-16 01:59:54 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
18-10-16 01:59:54 INFO (MainThread) [hassio.utils.gdbus] Introspect de.pengutronix.rauc on /
18-10-16 01:59:55 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: de.pengutronix.rauc - /
18-10-16 01:59:55 INFO (MainThread) [hassio.host.info] Update local host information
18-10-16 01:59:55 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
18-10-16 01:59:55 INFO (MainThread) [hassio.host.services] Update service information
18-10-16 01:59:55 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
18-10-16 01:59:55 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {‘hassio-supervisor’}
18-10-16 01:59:55 INFO (MainThread) [hassio.host.services] Reload local service hassos-apparmor.service
18-10-16 01:59:55 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
18-10-16 01:59:55 INFO (MainThread) [hassio.hassos] Detect HassOS 1.9 on host system
18-10-16 01:59:55 INFO (SyncWorker_1) [hassio.docker.hassos_cli] Found HassOS CLI homeassistant/armhf-hassio-cli with version 7
18-10-16 01:59:55 INFO (SyncWorker_0) [hassio.docker.interface] Attach to image homeassistant/raspberrypi3-homeassistant with version 0.80.1
18-10-16 01:59:56 INFO (MainThread) [hassio.addons.git] Load add-on /data/addons/git/a0d7b954 repository
18-10-16 01:59:56 INFO (MainThread) [hassio.addons.git] Load add-on /data/addons/core repository
18-10-16 01:59:56 INFO (MainThread) [hassio.addons] Load add-ons: 46 all - 46 new - 0 remove
18-10-16 01:59:57 INFO (SyncWorker_4) [hassio.docker.interface] Attach to image homeassistant/armhf-addon-mosquitto with version 2.0
18-10-16 01:59:57 INFO (SyncWorker_0) [hassio.docker.interface] Attach to image homeassistant/armhf-addon-duckdns with version 1.5
18-10-16 01:59:57 INFO (SyncWorker_3) [hassio.docker.interface] Attach to image homeassistant/armhf-addon-configurator with version 2
18-10-16 01:59:57 INFO (MainThread) [hassio.updater] Fetch update data from https://s3.amazonaws.com/hassio-version/stable.json
18-10-16 02:00:00 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
18-10-16 02:00:00 INFO (MainThread) [main] Run Hass.io
18-10-16 02:00:00 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
18-10-16 02:00:00 INFO (MainThread) [hassio.core] Ignore Hass.io auto updates on dev channel
18-10-16 02:00:00 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
18-10-16 02:00:00 INFO (MainThread) [hassio.addons] Startup initialize run 0 add-ons
18-10-16 02:00:00 INFO (MainThread) [hassio.addons] Startup system run 1 add-ons
18-10-16 02:00:00 INFO (SyncWorker_5) [hassio.docker.interface] Clean homeassistant/armhf-addon-mosquitto Docker application
18-10-16 02:00:04 INFO (SyncWorker_5) [hassio.docker.addon] Start Docker add-on homeassistant/armhf-addon-mosquitto with version 2.0
18-10-16 02:00:09 INFO (MainThread) [hassio.addons] Startup services run 1 add-ons
18-10-16 02:00:09 INFO (SyncWorker_4) [hassio.docker.interface] Clean homeassistant/armhf-addon-duckdns Docker application
18-10-16 02:00:13 INFO (SyncWorker_4) [hassio.docker.addon] Start Docker add-on homeassistant/armhf-addon-duckdns with version 1.5
18-10-16 02:00:18 INFO (SyncWorker_6) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant Docker application
18-10-16 02:00:20 INFO (SyncWorker_6) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.80.1
18-10-16 02:01:11 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
18-10-16 02:01:11 INFO (MainThread) [hassio.addons] Startup application run 1 add-ons
18-10-16 02:01:11 INFO (SyncWorker_17) [hassio.docker.interface] Clean homeassistant/armhf-addon-configurator Docker application
18-10-16 02:01:16 INFO (SyncWorker_17) [hassio.docker.addon] Start Docker add-on homeassistant/armhf-addon-configurator with version 2
18-10-16 02:01:21 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
18-10-16 02:01:21 INFO (MainThread) [hassio.core] Hass.io is up and running
18-10-16 02:06:21 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
How about the other things I asked?
I don’t understand it, I used /dev-info and things seem to be back to normal.
Is this a browser cache issue?
It doesn’t make sense to me that it could be but then I don’t know enough about Hassio yet.
Thanks for your patience and help!
on the dev-info there should be a little circular arrow in the very bottom right, clicking that should load logs, check if there is anything that doesnt look right in there
Here are the entries;
Could not contact Home Assistant Update to check for updates
October 15, 2018, 11:01 PM components/updater.py (ERROR)
Error fetching description at 192.168.1.217
October 15, 2018, 10:06 PM ssdp.py (WARNING)
Error fetching description at 192.168.1.174
October 15, 2018, 10:01 PM ssdp.py (WARNING)
Timer got out of sync. Resetting
October 15, 2018, 10:01 PM core.py (ERROR)
Ended unfinished session (id=93 from 2018-10-16 00:27:29.904238)
October 15, 2018, 10:00 PM components/recorder/init.py (WARNING)
that looks like the main section of that page. at the very bottom there should be text that reads
Press the button to load the full Home Assistant log. and to the far right of that there is a round arrow (click that) and it should show more log.
What shows in the main section is pretty much what shows in the bottom section when Log button is selected;
2018-10-16 07:10:03 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=94 from 2018-10-16 02:00:47.890609)
2018-10-16 07:10:20 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-10-16 07:10:24 WARNING (SyncWorker_19) [netdisco.ssdp] Error fetching description at 192.168.1.174
2018-10-16 07:15:38 WARNING (SyncWorker_1) [netdisco.ssdp] Error fetching description at 192.168.1.217
2018-10-16 08:10:10 ERROR (MainThread) [homeassistant.components.updater] Could not contact Home Assistant Update to check for updates
