hi
i have tried the new lovelace gui editor.
it is great but i wanted to use a custom card.
i put the resources text in the raw editor and saved.
now i get only a white screen.
setting the mode to yaml i can use my yaml file.
Now my question:
how can i delete the text in the raw editor?
i get only a white screen when i remove the mode yaml entry.
this text from the raw editor is saved in the home-assistant_v2.db
how can i edit the database and delete the entry?
i was wrong i cant find the text in the home-assistant_v2.db
where is the data stored from the ui editor?
Dixey
4
ssh root to your HA host. the file you are looking for is /configure/.storage/lovelace. You can safely delete it.
thank you taht fixed my problem
