Broken hass-supervisor
Hello
After some tries upgrading the HASSIO-supervisor (I am running HA on docker), and reboots, I can not start the hassio-supervisor docker image.
It seems like the root-user is missing somehow…
Does anyone have a clue on how I can either fix this, or reinstall hassio-supervisor without removing the HA-dockers (HA is running, but the supervisor is not):
journalctl -f -u hassio-supervisor.service
-- Logs begin at Mon 2021-02-22 14:56:22 CET. --
feb. 25 17:09:08 fatSmarty hassio-supervisor[588123]: [fix-attrs.d] done.
feb. 25 17:09:08 fatSmarty hassio-supervisor[588123]: [cont-init.d] executing container initialization scripts...
feb. 25 17:09:08 fatSmarty hassio-supervisor[588123]: [cont-init.d] udev.sh: executing...
feb. 25 17:09:08 fatSmarty hassio-supervisor[588123]: foreground: warning: unable to spawn /var/run/s6/etc/cont-init.d/udev.sh: Permission denied
feb. 25 17:09:08 fatSmarty hassio-supervisor[588123]: [cont-init.d] udev.sh: exited 127.
feb. 25 17:09:08 fatSmarty hassio-supervisor[588123]: [cont-finish.d] executing container finish scripts...
feb. 25 17:09:08 fatSmarty hassio-supervisor[588123]: [cont-finish.d] done.
feb. 25 17:09:08 fatSmarty hassio-supervisor[588123]: [s6-finish] waiting for services.
feb. 25 17:09:08 fatSmarty hassio-supervisor[588123]: [s6-finish] sending all processes the TERM signal.
feb. 25 17:09:11 fatSmarty hassio-supervisor[588123]: [s6-finish] sending all processes the KILL signal and exiting.
feb. 25 17:09:12 fatSmarty systemd[1]: hassio-supervisor.service: Main process exited, code=exited, status=1/FAILURE
feb. 25 17:09:12 fatSmarty systemd[1]: hassio-supervisor.service: Failed with result 'exit-code'.
feb. 25 17:09:17 fatSmarty systemd[1]: hassio-supervisor.service: Scheduled restart job, restart counter is at 1.
feb. 25 17:09:17 fatSmarty systemd[1]: Stopped Hass.io supervisor.
feb. 25 17:09:17 fatSmarty systemd[1]: Starting Hass.io supervisor...
feb. 25 17:09:17 fatSmarty docker[588585]: hassio_supervisor
feb. 25 17:09:17 fatSmarty systemd[1]: Started Hass.io supervisor.
feb. 25 17:09:18 fatSmarty hassio-supervisor[588660]: [s6-init] making user provided files available at /var/run/s6/etc...exited 0.
feb. 25 17:09:18 fatSmarty hassio-supervisor[588660]: [s6-init] ensuring user provided files have correct perms...s6-envuidgid: fatal: unknown user: root
feb. 25 17:09:18 fatSmarty hassio-supervisor[588660]: s6-envuidgid: fatal: unknown user: root
feb. 25 17:09:18 fatSmarty hassio-supervisor[588660]: exited 0.
feb. 25 17:09:18 fatSmarty hassio-supervisor[588660]: [fix-attrs.d] applying ownership & permissions fixes...
feb. 25 17:09:18 fatSmarty hassio-supervisor[588660]: [fix-attrs.d] done.
feb. 25 17:09:18 fatSmarty hassio-supervisor[588660]: [cont-init.d] executing container initialization scripts...
feb. 25 17:09:18 fatSmarty hassio-supervisor[588660]: [cont-init.d] udev.sh: executing...
feb. 25 17:09:18 fatSmarty hassio-supervisor[588660]: foreground: warning: unable to spawn /var/run/s6/etc/cont-init.d/udev.sh: Permission denied
feb. 25 17:09:18 fatSmarty hassio-supervisor[588660]: [cont-init.d] udev.sh: exited 127.
feb. 25 17:09:18 fatSmarty hassio-supervisor[588660]: [cont-finish.d] executing container finish scripts...
feb. 25 17:09:18 fatSmarty hassio-supervisor[588660]: [cont-finish.d] done.
feb. 25 17:09:18 fatSmarty hassio-supervisor[588660]: [s6-finish] waiting for services.
feb. 25 17:09:18 fatSmarty hassio-supervisor[588660]: [s6-finish] sending all processes the TERM signal.
feb. 25 17:09:21 fatSmarty hassio-supervisor[588660]: [s6-finish] sending all processes the KILL signal and exiting.
feb. 25 17:09:22 fatSmarty hassio-supervisor[589047]: hassio_supervisor
feb. 25 17:09:22 fatSmarty hassio-supervisor[589060]: [s6-init] making user provided files available at /var/run/s6/etc...exited 0.
feb. 25 17:09:22 fatSmarty hassio-supervisor[589060]: [s6-init] ensuring user provided files have correct perms...s6-envuidgid: fatal: unknown user: root
feb. 25 17:09:22 fatSmarty hassio-supervisor[589060]: s6-envuidgid: fatal: unknown user: root
feb. 25 17:09:22 fatSmarty hassio-supervisor[589060]: exited 0.
feb. 25 17:09:22 fatSmarty hassio-supervisor[589060]: [fix-attrs.d] applying ownership & permissions fixes...
feb. 25 17:09:22 fatSmarty hassio-supervisor[589060]: [fix-attrs.d] done.
feb. 25 17:09:22 fatSmarty hassio-supervisor[589060]: [cont-init.d] executing container initialization scripts...
feb. 25 17:09:22 fatSmarty hassio-supervisor[589060]: [cont-init.d] udev.sh: executing...
feb. 25 17:09:22 fatSmarty hassio-supervisor[589060]: foreground: warning: unable to spawn /var/run/s6/etc/cont-init.d/udev.sh: Permission denied
feb. 25 17:09:22 fatSmarty hassio-supervisor[589060]: [cont-init.d] udev.sh: exited 127.
feb. 25 17:09:22 fatSmarty hassio-supervisor[589060]: [cont-finish.d] executing container finish scripts...
feb. 25 17:09:22 fatSmarty hassio-supervisor[589060]: [cont-finish.d] done.
feb. 25 17:09:22 fatSmarty hassio-supervisor[589060]: [s6-finish] waiting for services.
feb. 25 17:09:22 fatSmarty hassio-supervisor[589060]: [s6-finish] sending all processes the TERM signal.
feb. 25 17:09:25 fatSmarty hassio-supervisor[589060]: [s6-finish] sending all processes the KILL signal and exiting.
feb. 25 17:09:26 fatSmarty systemd[1]: hassio-supervisor.service: Main process exited, code=exited, status=1/FAILURE
Which one of the three containerised methods are you using?
Only OS and Supervised support the supervisor. If you are using the container version of Home Assistant this is not supported.
