Broken integration notification
Today i had an integration stop working, the Growatt Server, after reading the breaking changes etc i thought something had changed so i removed and re-added the integration and had the same result. after some digging, by going to the documentation and then to the github i found others with the issue where something has changed server side that has broken the integration for now…
Perhaps a way to identify broken integrations could be implemented similar to the way updates are displayed? something like is it down right now for integrations…
Do you mean like this?
Yes, along the lines of that, but have them show up on the integration in home assistant itself… right where it lists how many entities are related to the integration
Interesting idea. Not sure how feasible it is but I’ll vote for it. You should too as it is your idea.
Refs:
https://github.com/home-assistant/alerts.home-assistant.io/issues/8
https://github.com/home-assistant/core/pull/45333
https://github.com/home-assistant/core/pull/50910
https://github.com/home-assistant/frontend/issues/3818
Noice.
The devs are ahead of you Chris. :slight_smile:
