I ran the HA Config Add-on to check if my config would work with 0.101.1. It’s failing with this error:
Failed config
General Errors:
- Component error: august - No module named ‘dateutil’
I think this may have to do with my August locks
Anyone know what’s going on?
Looks like this was fixed in 0.101.2.
ddjobe
3
I just ran Check Home Assistant configuration against 101.2 and got the same error.
cap60552
(John Wohlers)
5
I’m seeing the same error when running 101.3 and checking against 102.1.
Is this truly a failure, or will the real thing load just fine?
