Broken Panel_Iframe Shortcuts: Incorrect Router, SSL, Base Url setting?
A few things I’ve noticed that might help focus the issue:
  • Although my config.yaml specifies http://192.168.1.115:3218 as the url for configurator shortcut, when I click the link my browser launches https://192.168.1.115:8123/configurator. In other words, the link changes my http:// to https:// and changes port 3218 to 8123.
  • I run into a similar problem when I try to connect from outside my local network. When I click the configurator link, my browser tries to go to: https://[my customdomain].duckdns.org:8123/configurator. The page never seems to load.
  • Hassio.local has never worked for me, but typing the IP directly has always worked.
  • My router is set to forward ports 443 and 8123 to my local HA IP, but I have not created a rule forwarding 3218. Is that what’s wrong?
I imagine this is a really simple problem, but I’m completely stumped. Thanks in advance for the help!
I’m not exactly sure if I’m saying this correctly, but I’m running HA version 0.60 on hassio.
