After updating to 118 i sometime receive this couple of errors:
BrokenPipeError: [Errno 32] Broken pipe
ConnectionResetError: Cannot write to closing transport
When this happen, the front end is not accessible for some 30-40 seconds or even more (not clear to me). Looks like a restart of home assistant is needed to fix the situation.
Any idea on how to solve or what could be the cause of this?
Thank you in advance.
The complete errors in the log:
2020-12-11 22:14:06 ERROR (MainThread) [aiohttp.server] Error handling request
File "/srv/homeassistant/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
resp = await self._request_handler(request)
File "/srv/homeassistant/lib/python3.9/site-packages/aiohttp/web_app.py", line 499, in _handle
resp = await handler(request)
File "/srv/homeassistant/lib/python3.9/site-packages/aiohttp/web_middlewares.py", line 118, in impl
return await handler(request)
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/components/http/forwarded.py", line 71, in forwarded_middleware
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/components/http/request_context.py", line 18, in request_context_middleware
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/components/http/ban.py", line 72, in ban_middleware
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/components/http/auth.py", line 127, in auth_middleware
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/components/http/view.py", line 129, in handle
result = await result
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/components/websocket_api/http.py", line 42, in get
return await WebSocketHandler(request.app["hass"], request).async_handle()
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/components/websocket_api/http.py", line 233, in async_handle
await self._writer_task
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/components/websocket_api/http.py", line 81, in _writer
await self.wsock.send_str(message)
File "/srv/homeassistant/lib/python3.9/site-packages/aiohttp/web_ws.py", line 300, in send_str
await self._writer.send(data, binary=False, compress=compress)
File "/srv/homeassistant/lib/python3.9/site-packages/aiohttp/http_websocket.py", line 687, in send
await self._send_frame(message, WSMsgType.TEXT, compress)
File "/srv/homeassistant/lib/python3.9/site-packages/aiohttp/http_websocket.py", line 656, in _send_frame
await self.protocol._drain_helper()
File "/srv/homeassistant/lib/python3.9/site-packages/aiohttp/base_protocol.py", line 87, in _drain_helper
await waiter
File "/usr/local/lib/python3.9/asyncio/selector_events.py", line 943, in _write_ready
n = self._sock.send(self._buffer)
2020-12-11 22:14:29 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:30
2020-12-11 22:15:00 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/srv/homeassistant/lib/python3.9/site-packages/aiohttp/http_websocket.py", line 673, in ping
await self._send_frame(message, WSMsgType.PING)
File "/srv/homeassistant/lib/python3.9/site-packages/aiohttp/http_websocket.py", line 650, in _send_frame
self._write(header + message)
File "/srv/homeassistant/lib/python3.9/site-packages/aiohttp/http_websocket.py", line 660, in _write
raise ConnectionResetError("Cannot write to closing transport")
