Brother Integration not working with 2024.3
Updated to 2024.3. Everything works well, except for my Brother integration not finalizing the initializing phase. This stops Home Assistant from fully starting when it boots up. Can’t ask it to reboot. Have to delete or disable the Brother integration and shut down my entire VM to get Home Assistant to fully start
I see you have opened an issue already. :+1:
Might also be worth reporting this in the blog release topic.
Will do! For future reference, do I need to submit here and Github or if I submit in one or the other it’s sufficient?
Github will definitely be seen and hopefully actioned by the devs. This is the best action to take.
Reporting in the blog post (with the issue link) will be seen by users in a similar situation. This is a nice thing to do.
