Brownie 8IN8R home automation module
Dear Home Assistant community,
My name is Artem, and I’m cheer on home automation for a long time :smiling_face_with_three_hearts: . I used a lot of devices from different producers, but mostly I was unhappy.
Many devices have certain problems, such as:
  • Proprietary software. This is the biggest headache. We have many incidents when a manufacturer closed access to a device after a certain time, motivating you to buy a new device or use their service.
  • Closed API for integrations. There are many devices that have their own apps on Google Play or the App Store, but there is no open protocol for communicating with the Home Assistant. I don’t want to have a million different apps on my phone to turn off the kitchen light.
  • Lack of local control. Lights in your toilet should not be controlled by servers in another part of the world. Poor internet connection should not affect the smart home system.
  • Batteries and accumulators. When you have one battery-powered device, that’s fine, but when you have a whole house of these devices, so it’s a real challenge to replace batteries. Moreover, batteries are not eco-friendly.
  • Long reaction. I have met devices with a very long reaction to events. It was funny when the light turned on after I had already passed the corridor.
  • High price. Well, everything is clear here.
    I tried to take all these disadvantages into account to find a new solution without these minuses. After that I managed to develop a truly cool solution. So, meet the new hero, It is a Brownie 8IN8R module. :star_struck:
In my experience, I can say that this device covers 80% of smart home needs! Here is a small list of what this device can control:
Table
Now I will tell you about the main technical characteristics:
A heart and soul of the module is ESP32, Brownie 8IN8R has 8 discrete inputs with galvanic isolation and 8 relay outputs at 10A. In addition, the module has an Ethernet port. As practice has shown, wired technologies are more reliable and faster than wireless ones. The Brownie 8IN8R ping over the cable is <1 ms. WI-FI and Bluetooth are also here.
Additionally, there is easy access to the RX and TX outputs for flashing the module.
Now let’s talk directly about the firmware.
There are a lot of interesting projects for ESP32, but I made my choice in favor of ESPHome. Thanks to this project, it is possible to make firmware for Brownie instantly, after that the module is natively integrated into the Home Assistant. In addition, automation can be written in ESPHome, which will speed up sensors and active components interaction. For example, a motion sensor is triggered and the relay to which the light bulb is connected is immediately switched on. Moreover, automations work without the main server. Home Assistant may be unavailable for one reason or another, but this is not a reason to sit without light.
I want to show you a live example of the code at my house. I have 2 garage doors, a motion sensor in the garage and a leak sensor in the service room.
Code
esphome:
  platform: ESP32
  board: esp-wrover-kit
ethernet:
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO0_IN
  phy_addr: 0
  manual_ip:
    static_ip: 192.168.1.66
    gateway: 192.168.1.1
    subnet: 255.255.255.0
# Enable Home Assistant API
api:
ota:
web_server:
  port: 80
i2c:
  sda: 13
  scl: 16
pcf8574:
  - id: 'pcf8574_hub'
    address: 0x20
    pcf8575: true
# Individual inputs
binary_sensor:
  - platform: gpio
    pin:
      pcf8574: pcf8574_hub
      number: 6
      inverted: False
      mode:
        input: true
  - platform: gpio
    pin:
      number: 4
      inverted: False
      mode:
        input: true
  - platform: gpio
    name: "MH Service Room Leak Sensor"
    device_class: problem
    pin:
      number: 7
      inverted: False
      mode:
        input: true
  - platform: gpio
    name: "MH Garage Motion Sensor"
    device_class: motion
    pin:
      number: 5
      inverted: False
      mode:
        input: true
switch:
  - platform: gpio
    inverted: true
    internal: true
    pin:
      number: 14
      inverted: False
      mode:
        output: true
    restore_mode: ALWAYS_OFF
  - platform: gpio
    inverted: true
    internal: true
    pin:
      number: 15
      inverted: False
      mode:
        output: true
cover:
    name: "MH Garage Right Door"
    device_class: garage
    lambda: |-
      if (id(mh_garage_right_door_end).state) {
        return COVER_OPEN;
      } else {
        return COVER_CLOSED;
    open_action:
      - switch.turn_on: mh_garage_right_switch
      - delay: 1s
      - switch.turn_off: mh_garage_right_switch
    close_action:
      - delay: 1s
    stop_action:
      - delay: 1s
    optimistic: false
    name: "MH Garage Left Door"
    lambda: |-
      if (id(mh_garage_left_door_end).state) {
        return COVER_OPEN;
      } else {
    open_action:
      - switch.turn_on: mh_garage_left_switch
      - delay: 1s
      - switch.turn_off: mh_garage_left_switch
    close_action:
      - delay: 1s
    stop_action:
      - delay: 1s
    optimistic: false
This is how integration looks like into the home assistant dashboard.
Now let’s talk about the cost. The cost of one module is $ 100. I think this is a decent price for such a multifunctional module.
In my plans:
  • Expand the range of devices and their functionality. A module for 16 discrete inputs has already been designed.
  • Finish the project website.
  • Find a job. My skills: Golang, SQL, HTML and System Adminastrator (Windows). Home Automation systems integrator. 28 years old. Relocation is preffered :airplane:.
100 of whose $?
I assume the relays are designed to switch mains voltages. What certifications do you hold?
USA dollars.
The relay certified as UL Recognized (File No. E41515), CSA Certified (File No. LR31928) and EN/IEC, VDE (Certified/No.40009467). Datasheet.
Thanks.
I am not 100% sure, but I think in AU/NZ the whole beast would have to be certified, but I am not really sure on that.
Your device looks really great.
Thank you! I have great plans to develop this direction (add POE version, TRIAC verison to smooth voltage regulation, etc… But it is impossible due to the situation in my country. So, I’m looking for a job in EU, Canada, Australia to develop cool things.
