Hi, So I can login to 8123 just fine, after logging out I see the login splash screen as expected. However just refreshing the browser automatically enters back into HA. I did not check “Remember” either. Would like to have a bit of security if possible What am I doing wrong? Thanks Tom
Do you have a known network configured? If you do that’s why.
Hmmm, I may have done that, where can I look to know? My main concern is security as I would like to do remote access and open port 8132 thru the firewall. What is the best way to implement this? Thanks, Tom
in config.yaml
http:
trusted_networks:
- 192.168.0.0/24
that will prevent you needing the password, just take out the trusted_network bit and leave whatever else you have under that section
