On my tablet I am running fully kiosk browser to display home assistant.
I made an automation using the service browser_mod.popup that shows my frontdoor camera fullscreen when a motion is detected or the doorbell is pressed.
It works fine when using home assistant with a regular browser on my tablet but not when using fully kiosk browser.
Should it or is there a way to achieve this ?
I have nearly the same issue here. Pop up on my chrome browser on the notebook works fine, but not on my wall mounted tablet. Either in the chrome browser nor when using fully kiosk.
Have you meanwhile figured out a solution? Would appreaciate if you share it.
Thanks!
ok, it was really simple to overcome this problem.
Just forgot to register the browser in browser_mod and afterwards a browser refresh helped to get it run as expected.
Hi, Thanks for the info, had same issue, and restarting the Fully Kiosk fixed the issue!
