Same problem here
Problem with actions within a popup is due to the new hass-action being incompatible with browser_mod
From my experience, native HA cards are unaffected, and custom-button-card also still work
However v3 of mushroom cards uses the new hass-action and therefore do not function
Iāve rolled back mushroom card to 2.8.1 for the moment.
fingers crossed we see a fix for browser_mod soon
(and hoping thomasloven is well and just a bit busy this year)
@nullae - Appreciate the explanation, and the suggestion to roll-back a version on the Mushroom Cards.
Is there a way to roll back Mushroom cards from the HACS gui, or do i need to redownload the files and put them in place manually?
- I figured it out. For others that read this, select Redownload from the overflow menu. Then choose the version to download and then reload.
Yes, re-download in three-dot-menu and choose the wanted version.
With release 2.3 I cant change the popup background colour. Probably related to the changelog āChanges to popup formatting to be more consistent with built-in dialogsā.
Under style, --popup-background-color no longer works, and I have tried --primary-background-color and --popup-primary-background-color which likewise donāt work.
Any ideas?
Latest commit almost certainly fixed it. Wait for next release!
(I reported the bug and itās closed now.)
Same here. Created an issue.
Oh⦠i updated, but i didnāt had time to test it. Iāll try and see. Thanks!
If anyone else is having issues with pop-ups not being full screen on 2.3.0 I opened an issue.
āmdc-theme-surface works.
However, I cannot find the styling for header text (card title) color.
The pop-up cards on my iPhone are suddenly full-screen, and I canāt click out of them. The same cards in the same view look and work fine in a Win browser, but on the iPhone, I need to force quit the Companion app to get off the pop-up card.
I have Mushroom cards inside the pop-ups. Iāve rolled Mushroom back several versions, but that doesnāt seem to make a difference.
EDIT: Completely removed Browser Mod from configuration.yaml and from Integrations. Reloaded in HACS, re-added integration, restarting HA in between. Cleared caches on devices. Pop-ups are still full screen on iOS. Gah.
EDIT 2: I went through and removed all of my type: custom:popup-card cards, and am now successfully using fire-dom-event in its place. That didnāt work for me with previous (much older?) versions of browser_mod. However⦠still no improvement on iOS.
same issue for me⦠i have just started using this as well
Did you have a look at the other reply on the post you replied?
Just an update: my media player in browser mod remains constantly unavailable. Other entities are fine, though. Turning āregisterā off and on again doesnāt help - medai player remains unavailable.
Can someone maybe support me in having a script only runned on the device where it is triggered from?
It is a tap action on a dashboard:
- action: none
image: /local/ui/sidebar/roboter_off.png
style:
left: 11.7%
top: 34%
width: 20.5078125%
tap_action:
action: call-service
service: script.floorplan_roboter_change_eg
type: image
And the script:
sequence:
- service: browser_mod.navigate
path: /lovelance-floorplan/vacuum_erdgeschoss
enabled: true
But the issue I have is that the path is changed on all registered browser and I want to do it ONLY on the one which is triggering the script.
Thanks!
Not full screen on Android however thereās now a very unfinished looking title and X in the top left corner and also can not toggle anything thatās in the popup. Although if a light is already on I can use the slider to adjust the brightness, just cannot turn the light off.
same with me, all styles gone and its fullscreen where I canāt even close it
I now have that same title and X, so I can close the window. And my mushroom cards within the pop-up are all working.
If I remove the defined title from the pop-up, the X and title are replaced with ātrueā, and I canāt close the pop-up.
Working:
entity: climate.xxxxxxxxxxxxxxxxxx
tap_action:
action: fire-dom-event
browser_mod:
service: browser_mod.popup
title: Basement
content:
Not working:
tap_action:
browser_mod:
title: ''
content:
The duplicated titles look bad, but at least itās working now. @wardozer, do you have a title defined in your pop-up?
Ya when then its working and i can close, but none of the styles i defined are not working. Is style working for you?
