The PopUp appears but the button does work.
What i am doing wrong?
Edit: Replaced action: light.turn on with service: light.turn_on and it works. So the former service calls are not adapted to action calls in Browser Mod?
Did you clear cache AND scripts? In windows - chrome/edge this is done by pressing F12 (open developer tools) then right-click on refresh icon and select āEmpty cache and hard restartā. Just pressing ctrl+F5 usually doesnāt help, since this only clears cache, but not js files etc.
So I rolled back my install from 2025.1.1 after having some issues with browser_mod and a couple other integrations. I see there is a new update for Browser Mod, Iām still on 2.3.1, however Iām not seeing it on my update list. Do I need to install HA Core 2025.1 for it to appear?? Any thoughts?
Yes to both.
TBH, for the first one I donāt have the solution at hand so youāll have to do some searching on how to determine when a device has no activity for x time.
For the second one: you donāt even need browser_mod for this.
In your profile settings (bottom of the side bar) you can define the default dashboard for that device which is stored in your browser session.
Thanks for your answer.
There are indeed functions call available to know when device become inactive:
I followed this post which seems to be working: Switch back to default dashboard after some time - #4 by Ldc2335
Iāll probably end up to make another one to dim/wake the screen based on movement as well.
Thanks for the second point ! I totally forgot that this was available.
has anyone seen issues with browser_mod not reconnecting to HA after an HA reboot? currently need to manually go and refresh the browser for it to reconnect.
Iām trying to use a popup that activates when pressing a button. On my PC/tablet, it works perfectly and displays in three columns. However, on my phone, I want it to display as one column per card because three columns result in awkwardly sized cards. How can I make the popup responsive so it automatically shows three columns on PCs/tablets and one column on phones?
this is the code so far
Simple question apparently not with an easy answer⦠how do I style the title text of a popup? Literally I just want to change the color, but digging through the shadow DOM and so forth defies me. This is the closest that Iāve gotten, though it only styles the button text:
How can I register a TLC Google TV in browser_mod? My goal is to use the Dashboard Screen Saver app (Google Play) to show a a Home Assistant Dashboard as a screensaver without needing to login.
I am trying to get a browser_mod.more_info to work only on the browser where I clicked. it currently pops up on all browsers in the house. I found browser_id: this and deviceID: this but they donāt do anything. Can somebody help me get this working?
I am running the latest 2.3.3 but no sensors are working.
Battery. charging etc.
It will only update battery sensors when the browser is started, but then failes to update over timeā¦
The screen on/off and screen sensor seems to always work.
Am I missing something?
I wanted to share a quick CSS addition for browser_mod that I just implemented, which considerably improves the visual attractiveness of blacking out a browser screen.
Create a .css file (I named it browser_mod_extra_css.css) and place this in it:
body > .browser-mod-blackout {
transition: background .2s ease-in-out;
body > .browser-mod-blackout[dark] {
transition: background 2s ease-in-out;
Save it, and store it in your home assistant /www folder.
Then add it as an extra Stylesheetresource (/local/browser_mod_extra_css.css).
Refresh your browser mod device, and try turning off its screen.
Now, the black fades in smoothly instead of a āhard cut to blackā, and when you āwakeā again, it fades out faster (.2s, or 200ms). You can change the durations to whatever you like! (and ofcourse, you can try setting other easing methods)
I tried playing TTS audio to the browser via the browser mod created media player, but thereās no output. When I use the āBrowse Mediaā button on the media player popup and select a radio station for example it works, but if I try to play TTS (either via action or via the Browse Media popup) it just stays silent. I can play TTS on my google home speakers, itās just the browser media player thats not working. Also no errors in HA logs or in the browser dev console. Am I missing something?
Iām having some problems
I have made a picture elements card, and some elements have an icon.
When i press the icon, i want it to toggle a script.
Turning the script on, should show a browser mod popup containing some info (for now a button)
However, i want it to popup where it was launched from⦠meaning one time from a tablet, the other time from al laptop.
So i think i need the device_id: THIS ?
I tried, but its not doing anything.
Heres my code:
